Strange headlight motor problem
Old Sep 9, 2001 | 01:40 AM
AS84's Avatar
AS84
Default Strange headlight motor problem
The passenger side headlight motor runs whenever the car is started and then again when the car is shut off. I raised the hood and I could see something turning on top of the headlight motor whenever I shut the car off, plus I could hear the thing run, and thoughts?
Old Sep 9, 2001 | 02:03 AM
phrogs's Avatar
phrogs
Veteran: Marine Corps
Default Re: Strange headlight motor problem (AS84)
The thing you saw turning is the dial that you use if the motor fails open the hood and spin it and the headlight will start to flip ans will stop once you get it all the way up or down as for why it is doing that I dont have a clue maybe the headlight relay is going bad it is located on the drivers side wheel well up by the turn singnals
good luck
Old Sep 9, 2001 | 05:34 PM
AS84's Avatar
AS84
Default Re: Strange headlight motor problem (phrogs)
Thanks phrogs- I'll check the relay out. Does it operate both headlights?
Old Sep 9, 2001 | 07:56 PM
jfb's Avatar
jfb
Each headlight motor has its own relay and there is a third relay that allows the right side headlight to close.
Old Sep 9, 2001 | 10:00 PM
phrogs's Avatar
phrogs
Default Re: Strange headlight motor problem (jfb)
yep on the early cars it was like this on my 89 it is a single relay hope i didnt confuse ya, Im not sure where they are on your 84 good luck.
To Strange headlight motor problem
By Michael S. Palmer | 2026-06-03 09:39:05
