After 2 months of pain with trying to find the source of the car's vibrating problems it turns out to be the ROTORS were warped. The wrench that put the brake pads on 2 months ago should've told me the first time that they were bad. After going back to the same person that installed them checked the car again and couldn't find anything wrong and that I was just crazy.
So I went to another brake man and explained the problem. He took it for a test drive down the highway and immediately figured it's the rotors that he was feeling. Anyway she's fixed and I can finally leave town with her.
It is understandable that you did not know what the vibration was, but a beginning auto mechanic should have picked up on that immediately. I recommend finding a new wrench for your ride.
Glad he isolated it and got it fixed. just to be accurate - most of us and a whole bunch of mechanics buy off on the "warped rotor" myth. turns out the rotors actually don't warp at all - instead the pick up brake pad material - and that unbalances the disk. Check out this excellent write up from stoptech, it fully documents and isvery well written to understand what is actually going on when the call "warped Rotor" goes out!
I'm glad you got your brakes and vibration fixed, and thanks for coming back and telling us the outcome.
While I agree to an extent with the Stoptech article we should remember a few things. Rotors have been getting thinner, and many are made poorly. It's a conscious, weight-saving and cost-saving movement and has been going on for twenty years. So, some of the "vibration' really IS warped rotors. Not just brake pad material transfer.
If you've ever seen $5 rotors, and I have, there is a minute, barely visible difference. And usually only when you do a side by side comparo with a really good or even OEM rotor.
Long way of saying it sometimes is cheap, or warping rotors and even the frequent overtightening lug nuts can have an effect on rotors and braking.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
With my background in heat treating and hot forming, I'll have to agree with Stoptech's position that brake rotors don't actually deform (warp).
In fact, rotor's receive a nice stress-relieving operation every time you make a good, hard stop from about 60mph.
Take a light cut on both surfaces to remove pad material, and they'll be good to go.
Larry
code5coupe
Ever over tighten the wheel BOLTS on a Beamer or VEEDUB? The rotors will WARP INSTANTLY, pulsating from the very first application of the pedal. Know this from experience, you have to torque them with a torque wrench. Ever pull a trailer with no trailer brakes? The front rotors of the truck turn BLUE and pulsate. Cant say for sure, but I would bet they were WARPED.
PS Ive chucked up rotors in the lathe that were so bad you could see the warpage with your eye
