Rebuilt A/C Lines
Old Aug 24, 2006 | 01:06 PM
mikey whipreck's Avatar
mikey whipreck
Default Rebuilt A/C Lines
I'm wondering if anyone has ever had their air conditioning lines rebuilt?
I have some lines are are cracked, and I found replacements online ($150 for the compressor line and $100 for the evaporator line). But a shop near me swears they can rebuild the lines to be like new for a fraction of the cost.
My feeling is , but I wanted to see if anyone else has gone this route. It'd be nice to keep the original equipment, and give the local boys some business- but i'm gonna dump alot of time into rebuilding my A/C system, I dont want it to leak...
Old Aug 24, 2006 | 01:11 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I had one of mine rebuilt several years ago when I accidentally broke it while removing my radiator to clean it.
No leaks. No problems at all. Fast turn-around time, too. Same-day service.
If you're having a hard time looking for a hose or don't want to spend hundreds of dollars, then having your a/c lines, a/c hoses, and fittings rebuilt or repaired by a reputable auto HVAC shop makes sense...at least for my budget.
Old Aug 24, 2006 | 10:14 PM
93*Corvette's Avatar
93*Corvette
Many companies will rebuild your lines. Cost about $75. As long as your metal fittings are good, and it just the rubber, you've got it made.
Also... You may want to contact www.corvettepartsman.com for new hoses. They sell pretty cheap...
Old Aug 24, 2006 | 10:35 PM
WEH 2000C5's Avatar
WEH 2000C5
Do you have the original oil still in your crankcase? You can carry this to extremes . I've had my lines rebuilt by a mom & pop radiator shop ,no problems.
Old Aug 25, 2006 | 12:24 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
My neighbor,who does mechanic work on the side,fixed a van that had a broken metal line...used a compression fitting and said as long as its on the low side theres really no problems.Fixes a/c lines all the time to save his customers money.if the metal lines are good but the hoses are bad,they can be done cheaper by those that rebuild them.
Old Aug 25, 2006 | 12:45 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Those prices are nuts. I found compressor lines listed for $90, and the accumulator line for $30 on my 85.
The accum line is discontinued though.
Have you checked Rockauto or Superior Chevy? Prices at CorvettePartsMan were almost double.
Old Aug 25, 2006 | 08:02 AM
mikey whipreck
Where'd you find the compressor line for $90?
Corvette-America still carries the accum line
In any case, It sounds like I'm going to just let that shop try and repair my lines.
Old Aug 25, 2006 | 09:15 AM
onedef92's Avatar
onedef92
I would. I guarantee you won't notice it at all.
Old Aug 25, 2006 | 10:36 AM
CentralCoaster
Superior Chevy. Actually I think it was 80 and change, I forget exactly.
I would only buy from that guy for discontinued parts. He's even more expensive than the catalogs.
Old Aug 26, 2006 | 12:14 AM
93*Corvette
Sorry about that... Here's why I recommend him... I was looking for a Accumulator to Evaporator hose for my 1993. I called over 50 different companies, which included all the big Covette companies, no one had it (and they couldn't get it).. This guy had it for $30... I would have been willing to pay up to $125 since I couldn't find it...
Right now, he has a 1992 Accumulator to Evaporator hose (which is a one year only part also) for only $32 If someone had a 1992, they wouldn't be able to find this hose anywhere... This guy has it for $32, how can you pass that up?
Old Aug 26, 2006 | 09:08 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
There's not a thing wrong with rebuilding lines if done properly. They simply reuse the metal parts and crimp on new hose. We do it at work sometimes on older trucks or for trucks other than our Kenworths when the OEM line is not available locally.
To Rebuilt A/C Lines
