intermittent stall/hesitation
Old Aug 24, 2006 | 05:57 PM
jnscott's Avatar
jnscott
Default intermittent stall/hesitation
Hi Folks,
I'm experiencing an intermittent stall/hesitation when under hard acceleration on my 88 Coupe. I feel like it could be a bad wire connection, since the fuel pressure is good (under load) and the plugs, wires, and filters are new. It does occur more often when cold vs. hot, and in left or right turns as well as straight line. Has anyone seen this before, or have and advise?
Thanks,
Jay
Old Aug 24, 2006 | 06:02 PM
RRT vette's Avatar
RRT vette
Make sure the plug wires are on good. Does it do this when reved in park? Does the service engine soon light come on? You have ruled out fuel as a problem I assume. You may want to have the ignition module tested and ohm the pickup coil. Others will give advise as well.
I've been through Daphne many times.
Old Aug 24, 2006 | 06:16 PM
jnscott's Avatar
jnscott
I've checked most everything I can think of. Coil, dist, cap and rotor. She runs fine most of the time, and then the quick one shot hesitation, only under heavy load. I just fixed a code 36 for the burn off relay, but have no other codes. I'm stumped!
Jay
Old Aug 24, 2006 | 06:21 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Does this happen when fuel level is under a 1/4 tank
If so, it's normal
Old Aug 24, 2006 | 08:47 PM
jnscott's Avatar
jnscott
yep I thought about that, so I filled up. Still did it just the next day.
Jay
Old Aug 24, 2006 | 09:09 PM
RRT vette's Avatar
RRT vette
The best way to tell what the problem is...is to run the car on a scan tool and see what happens when it stalls/hesitates. May be the MAF sending the wrong signal, but not bad enough for the ECM to throw a code. Take a look at the wires in the MAF for debris.
Old Aug 24, 2006 | 10:33 PM
Da Mail Man's Avatar
Da Mail Man
.....this sounds a bit like what i was going through and it turned out to be the start of a failing fuel pump.....maybe you can get something out of the following post.....
http://forums.corvetteforum.com/show....php?t=1446374
Old Sep 27, 2006 | 10:46 AM
jnscott's Avatar
jnscott
Update, Problem is now gone. Replaced fuel pump wire harness, found open contact at connector.
Old Sep 27, 2006 | 10:53 AM
RRT vette's Avatar
RRT vette
Thanks for the update. This will help me or all of us in the future as a place to check.
To intermittent stall/hesitation
