Dash Sensor
Old Aug 28, 2006 | 05:53 PM
hill's Avatar
hill
Default Dash Sensor
what does the dash sensor do on an 1990 non zr1 mine was missing when i got it i have one now i have to pull the dash to put in in just worning if it was worth it
Old Aug 28, 2006 | 10:22 PM
hill's Avatar
hill
no one knows?????????
Old Aug 28, 2006 | 11:54 PM
Red Dwarf's Avatar
Red Dwarf
What's the location of the sensor your referring to?
Old Aug 28, 2006 | 11:57 PM
qws's Avatar
qws
Are you referring to the control center that is above the radio?
Old Aug 29, 2006 | 05:17 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
It's an ambient light sensor. In high ambient light (like daytime) the interior lights stay off when door is opened.
Old Aug 29, 2006 | 08:10 AM
hill's Avatar
hill
its on the dash in the defrost vent by the windshield
Old Aug 29, 2006 | 10:53 AM
Red Dwarf's Avatar
Red Dwarf
That's your Sun load temp sensor.It's works with the a/c (electronic) to determine a/c needs.etc.
To remove, ( grille) pry up on the rear of the grille with a small flat screwdriver. Their are a couple of tabs holding it. Be careful, the plastic is probably brittle from sitting in the sun for all these years. There's an electrical connector you have to remove & the sensor is removed, quarter turn to the left.
Old Aug 29, 2006 | 10:56 AM
Red Dwarf's Avatar
Red Dwarf
[QUOTE=Red Dwarf]That's your Sun load temp sensor.It's works with the a/c (electronic) to determine a/c needs.etc.
To remove, ( grille) pry up on the rear of the grille with a small flat screwdriver. Their are a couple of tabs holding it. Be careful, the plastic is probably brittle from sitting in the sun for all these years. There's an electrical connector you have to remove & the sensor is removed, quarter turn to the left.[/QUOT
It's been a long time, but I think that's how it goes . Anybody else?
Old Aug 29, 2006 | 05:48 PM
hill's Avatar
hill
kool thanks
To Dash Sensor
