temp question
Old Sep 10, 2001 | 07:07 PM
dt35th's Avatar
dt35th
Default temp question
replaced thermostat, and flushed cooling system, know main fan turns on at 232 degrees, before i did work fan came on at 226, does anyone know what might have happened.
Old Sep 10, 2001 | 07:19 PM
GlockLT4's Avatar
GlockLT4
Default Re: temp question (dt35th)
Hmmmm.... did you mess with your ECT sensor? If you replaced it or knocked the connector it could be reading slightly different. You are going by the digital temp, right?
[Modified by Glock'94, 5:20 PM 9/10/2001]
Old Sep 10, 2001 | 07:25 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Only 2 thoughts for now:
Air in system - try packing - think this is most likely.
Flush disturbed crud that effected temp sensor (either ECM temp sensor or dash temp sensor).
Only way to determine turn on temp is to use a scanner to see what temp the ECM thinks the car is running. The ECM and dash sensors are in different locations on the engine and will never match.
Good Luck,
Pete
Old Sep 10, 2001 | 07:27 PM
dt35th's Avatar
dt35th
Default Re: temp question (Glock'94)
yes , I'm going by digital temp. where is the ECT sensor, is that the one connected to the radiator just below the fill opening
[Modified by dt35th, 6:30 PM 9/10/2001]
Old Sep 10, 2001 | 07:29 PM
GlockLT4's Avatar
GlockLT4
What year is it? If it is a 92+, then it will be right on the waterpump, i don't know about the L98
[Modified by Glock'94, 5:33 PM 9/10/2001]
Old Sep 10, 2001 | 07:31 PM
dt35th's Avatar
dt35th
its an 88
Old Sep 10, 2001 | 07:33 PM
GlockLT4's Avatar
GlockLT4
Hmm.. well, like I said, I'm not sure about the L98, but look around the waterpump area... or if you have a Hanes or Chiltons manual you should be able to find it in there.
Old Sep 10, 2001 | 07:36 PM
dt35th's Avatar
dt35th
[QUOTE]Hmm.. well, like I said, I'm not sure about the L98, but look around the waterpump area... or if you have a Hanes or Chiltons manual you should be able to find it in there.
Thanks for you help, I have Haynes I'll see if I can find it
[Modified by dt35th, 6:38 PM 9/10/2001]
Old Sep 10, 2001 | 07:39 PM
PeteL's Avatar
PeteL
On a stock 35th the ECM controls the main fan turn on temp - the ECM temp sensor is located below the throttle body in front of the engine.
The digi-dash uses it's own temp sensor for water temp located on the passenger side of the engine just above the starter.
If you have the aux fan it uses it's own temperature sensor (switch) located bewteen plugs 1 and 3 on the drivers side head.
Good Luck and let us know what you find. Still bet it's air.
Pete
Old Sep 10, 2001 | 07:45 PM
dt35th's Avatar
dt35th
Default Re: temp question (PeteL)
Do you know what the green wire is that is attacked the rad. just below trans. tube on fill side
To temp question
