Dana side yokes.. how to remove/replace?
Old Sep 3, 2006 | 03:47 PM
Bans25's Avatar
Bans25
Default Dana side yokes.. how to remove/replace?
How do I remove the side yokes from a Dana rear? I need to pull the center shaft, but its not a bolt.. looks like some kind of pin??
thanks
-Bill
Old Sep 3, 2006 | 04:22 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You'll need some very heavy duty snap ring pliers.
CFI-EFI's Avatar
CFI-EFI
If it is simply a roll pin, drive it out with an appropriately sized drift. My book shows a snap ring, just inboard of either spider pinion that have to be removed. The side yoke shafts are retained by select fit snap rings.
RACE ON!!!
PS. After doing some additional reading, it appears that the dual, snap rings, inboard of the spider pinions, was an early 1984 phenomenon and was recalled. The spider pin should be retained in the case by a roll pin, as most other manner of Dana differentials.
Old Sep 3, 2006 | 05:09 PM
redrose's Avatar
redrose
snap rings...healthy ones, need a good pair of snap ring pliers, no taiwan junk
Old Sep 3, 2006 | 05:15 PM
CFI-EFI's Avatar
CFI-EFI
To remove the spider pinion pin???
RACE ON!!!
Old Sep 3, 2006 | 07:28 PM
CentralCoaster
What are you trying to do? Remove the spider gears? or the axle yokes?
You need to remove the snap rings to get the yokes out, to get the side spider gears and carrier out.
Old Sep 4, 2006 | 01:12 AM
Bans25's Avatar
Bans25
I have a D44 that needs the side yokes installed, but not sure how to get the roll pin out.. The spider gears are still in there.. I don't think I can install the yokes withough removing the spider gears right?
Old Sep 4, 2006 | 02:50 AM
CentralCoaster
The side yokes go through the spider gear, then are held in place with a c clip.
Old Sep 4, 2006 | 06:58 AM
WVZR-1's Avatar
WVZR-1
Default D44 short axles
It sounds like you may have bought a D44 set up with ring and pinion but no short axles from someone. When you drop your carrier the removal of the short axles will become obvious. You DO NOT need to remove the pin to install the short axles. You will need "very stout" snap ring pliers. There could be another catch! The snap rings are "selective" and set end play of the short axles. You may not be able to use the snap rings from your take out.
End play with minimum tolerances are preffered. I've got complete sets of D44 "selective" snap rings. I've PM'd you my email if you need anything.
To Dana side yokes.. how to remove/replace?
