knock sensor woes
Old Sep 3, 2006 | 08:52 PM
hiwattvette's Avatar
hiwattvette
Default knock sensor woes
Well I have myself a nice little problem. I decided to change my knock sensor on my 85 since I have been getting a code 43 and it has been pinging.So I crawl under the car and proceed to TRY to loosen the sensor and (snap) the housing breaks off leaving just the threads sticking out of the block.I have tried heat,PB Blaster,and miscelaneous tools with no luck. Any suggestions would greatly be appreciated.
Old Sep 3, 2006 | 10:22 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Easyout
Old Sep 3, 2006 | 10:41 PM
redrose's Avatar
redrose
pull the drain plug out from the other side and put the new ks in there, extend wire as reqd
To knock sensor woes
