another look at reverse cooled heads
Old Sep 3, 2006 | 11:09 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default another look at reverse cooled heads
How's this for reverse flow cooled heads?
http://www.popularhotrodding.com/tec..._parts_engine/
Through an ingenious distribution system, water is plumbed to the heads beneath the exhaust ports, and returned via the core plug holes in the block.
Appearances can be deceiving, as a look inside the manifold reveals. The plenum intake was epoxy-filled over a plaster mold to effectively produce a single-plane manifold within its confines.
Old Sep 3, 2006 | 11:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
Jesuzz H!....Look at the size of that plenum....
Oh, and your thread will sink to the bottom of the page
Old Sep 3, 2006 | 11:31 PM
ALLT4's Avatar
ALLT4
Yeah, but what temp thermostat does that run?
Old Sep 3, 2006 | 11:37 PM
BrianCunningham
160 and he meantioned wanted to run the block and the heads at different temps
Old Sep 3, 2006 | 11:51 PM
cv67's Avatar
cv67
St. Jude Donor '05
Yeah, but thats not an LT1-You cant say that.
Old Sep 3, 2006 | 11:58 PM
BrianCunningham
Thanks for the bump
Old Sep 4, 2006 | 12:03 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Dang - some cool engineering
Old Sep 4, 2006 | 12:39 AM
ALLT4's Avatar
ALLT4
If it cools so well why does he need what's in the picture?
Old Sep 4, 2006 | 12:40 AM
bogus's Avatar
bogus
some serious thought went into that... wouldn't it have been easier to reverse the direction of the water pump???
Old Sep 4, 2006 | 12:41 AM
bogus's Avatar
bogus
headers are not cooled...
Old Sep 4, 2006 | 12:43 AM
ALLT4's Avatar
ALLT4
What, he only has tubes on those two? Hard to imagine he took all the rest off and just let that one on for the photo.
Old Sep 4, 2006 | 12:57 AM
91vette6spd's Avatar
91vette6spd
my 91 vette runs at 150 in south fl (boca) 160 therm,new rad, flow kooler pump, and added a relay so when the parking lites go on so dose the fan , no need for that work
Old Sep 4, 2006 | 01:16 PM
BrianCunningham
It is
All the other stuff helps cool the individual hot spots.
Take a look at his power curves, it puts out over 500hp @ 2500rpm
To another look at reverse cooled heads
