Is Opti Bad?
Old Sep 6, 2006 | 03:51 PM
meffordg's Avatar
meffordg
Default Is Opti Bad?
I am reposting this question from my other thread...just so its nice and simple to read.
In my other post I described how a spark plug and spark plug wires change has lead to back fire problems and the steps I went through to figure it out.
I have done all I can think off to figure out what the problem is -
Here is where I stand. By running the codes I have narrowed down cylinder two is not firing at all and 7 is firing intermitently. On Plug 2 I have changed plugs with a known good plug and I have changed wires with a known good wire and each time number two does not fire...
Could it be anything else but the Opti?
Thanks for your time and expertise
Old Sep 6, 2006 | 03:55 PM
bogus's Avatar
bogus
Nope.
It's time to replace the Opti. If the cap is that bad, then the rest of the unit isn't long for this world.
Great diagnostics, tho!
Old Sep 6, 2006 | 03:56 PM
toptechx6's Avatar
toptechx6
Any chance you have 2 & 7 crossed?
Old Sep 6, 2006 | 04:01 PM
bogus's Avatar
bogus
on the Opti, it would be one helluva trick.
The wires are parsed, odds and evens on opposite sides. It would take a lot of effort, and an extra long wire, to pull it off.
meffordg's Avatar
meffordg
No chance...I have checked the wiring 4 times...and they plug into the opti on opposite sides...
Old Sep 6, 2006 | 04:07 PM
RacerX70CC's Avatar
RacerX70CC
If you've got no spark and you've tried known good wires, it's a good bet your Opti cap is toast... AS the previous poster said, it's a good bet the Opti itself isn't far behind. FWIW, I have the MSD Optis and Opti cap/rotor kits... PM me for your forum pricing.
Old Sep 6, 2006 | 04:08 PM
toptechx6's Avatar
toptechx6
I see that after looking at the earlier post which has the cap diagram. Since 7 & 2 are adjacent in the firing order it does seem possible it could be an internal cap problem.
Old Sep 6, 2006 | 04:14 PM
meffordg's Avatar
meffordg
Okay let me ask you this question...Is there any validity to blowing compressed air into the intake portion of the Opti vent, in hopes of blowing debree out? Read it on Mike Chaneys Optispark Disection page
http://www.charm.net/~mchaney/optisprk/optisprk.htm
This problem did not happen till after a spark plug and wire change, so I am wondering if I knocked some dirt or grime loose and this might just blow it out (wishful thinking)
Old Sep 6, 2006 | 04:21 PM
RacerX70CC's Avatar
RacerX70CC
If this is the case and it ran ok before, then try this... get a can of brake cleaner (NOT carb cleaner) and shoot it into the spark plug wire hole on the Opti cap (where the wire plugs in at), NOT into the Opti itself (don't do that ever!). You'll likely get some road grime, etc that may be interfering with the connectivity of your plug wire. Clean it out, then blow it out with compressed air and wait about a 1/2 hour or so just to be safe (let the flammable liquid evaporate). Then plug the suspect wire back in and see if it still misses. If it stops... cool! If not, replace the cap/rotor at the minimum. Don't EVER blow anything into the Opti vent.
Hope this helps you!
Old Sep 6, 2006 | 04:39 PM
toptechx6's Avatar
toptechx6
I definitely agree with your thinking about it occuring after the plug and wire change but doubt you could do anything to the inside of the Opti and would not try the trick with the vent. Since it looks like you had some cracked plugs I'd be giving them a very careful inspection before jumping inside the distributor. The suggestion to check the cap for corrosion where the wires plug in is a good one, I always believe in rechecking recent work before imagining freak coincidence, best of luck.
Old Sep 6, 2006 | 05:02 PM
bogus's Avatar
bogus
This is what happend to Merlot's fiancee's car... the cap was bad. a couple of cylinders were dead.
Old Sep 6, 2006 | 05:03 PM
bogus's Avatar
bogus
I wonder if the material the cap is made from hasn't broken internally... what is that, bakelite still?
If that is the case, all the visual inspection in the world won't help.
Just drop the coin and get a new opti, complete.
Old Sep 6, 2006 | 05:07 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Question: if it is the Opti, would it be less expensive (and cost-effective based on miles, time-in-service) to replace the cap and rotor, or to replace the entire Opti?
Old Sep 6, 2006 | 05:34 PM
toptechx6's Avatar
toptechx6
I agree if it is indeed the cap, I just can't quit thinking the problem started with the plugs and wires. Coincidence? I'd hate to see him replace it and still have an issue. Humor me and swap #2 for #3 to see if it changes!
Oops, looking back I see he did swap plugs, sure seems like the cap and agree if you do that you might as well go for the gusto.
Old Sep 6, 2006 | 06:32 PM
Rumpelstiltskin's Avatar
Rumpelstiltskin
had a buddy who's opti went bad one night in dc. he wasnt happy.
Old Sep 9, 2006 | 05:36 AM
meffordg's Avatar
meffordg
I was able to get a small screwdriver with a test light in it...when I place the the screwdriver in number 2 socket I can tell there is electicity running through it, but very low...I placed the screwdriver in plug 4 and its twice as bright.
So if there is weak spark going into number 2, could this mean its something else besides the Opti or am I just being wishful in my thinking?
Old Sep 9, 2006 | 06:45 AM
tjwong's Avatar
tjwong
Sounds like a bad opti. Chances are the cap is wasted which is a common problem. You have a couple choices, replace the cap and rotor kit or the complete unit. Personally for all the work and what they get for the cap and rotor kit, its best to replace the complete unit. In doing so you can go with an OE new replacement, a reman unit or a MSD unit. Depending on where you get the new OE unit it can be a bit cheaper or about the same as getting a new MSD unit. A reman is the cheapest route but also you may run into problems later on.
To Is Opti Bad?
