Torque Vs HP...
http://s4wiki.com/wiki/Torque_and_HP
Good examples, pretty much relates to everything I've heard but I wanted to know what you guys thought regarding the L98 description in there....
The constant conflict we C4-owners are up against is picking up the upper RPM range and power without losing the low end power. Have our cake and eat it too. The article points out the only way to do that is to raise the torque curve thoughout the entire range. Simply shifting the torque curve to the right kills low end.
But if we are willing to put in steeper gears along with a shift of the power curve to the right, then we are in and out of the low rpm range so quickly we get a net gain even if we have only moved the torque curve to the right. But in this case we also need more rpms or we end up at max power before we get to the finish line. I thought the example in the article comparing the L98 to the LT1 was an excellent illustration of this.
That article doesn't clarify anything. It's way too long winded and brings up more questions than answers.
It's hard to keep it short and sweet, but here's my attempt to explain myself in another thread. The last part sums it up better:
Power is what moves things. An impact wrench puts out more torque than your motor, but very little power. It will hardly move the car. Yes, torque can be figured by dividing out the engine speed, but it really tells you nothing useful about how fast the car is... You would also need to know the corresponding engine speed (whoops, you just calculated power!)
The smart guy in the bike lane next to you is in 2nd gear, and spinning away at the pedals, and keeping up with you. While sipping a margarita.
You're putting down way more torque. But you're both going the same speed, because you're both putting down the same amount of power.
Now, you get to the top of the hill and take a breather. The guy next to you laughs and keeps on going...
"Torque tells you everything about how fast the car is! A car will accelerate at the EXACT rate as the torque curve of the engine. "
A car with constant power will not accelerate at a constant rate. It takes more power to go from 90-100 than from 50-60.
Anyhow, take your torque curve and experiment with shift points. Try to maximize the area under the curve. Guess what the area under the curve is? It's Torque x RPM. Gee, you just calculated power again! The car with the most power between shift points will win, all else being equal, and ignoring torque, since it doesn't matter.
here's my writeup i keep handy so i just have to cut and paste my argument:
*** Talk about Torque ***
Torque is an *instantaneous* twisting force. Look at the units. It is not energy, and there is no time component. It is in terms of force at the end of a lever.
We can't really measure an instantaneous force. To do so requires removing the time component. This means we would be attempting to represent the Universe as having one less dimension than it really does.
That's an abstract thought, but reality bears it out. Consider, for instance, using a strain gauge to measure the torque/force. We could cut out a section of the driveshaft and replace it with a strain gauge. The only way we could get meaningful data is to average it over time, or the gauge would show wildly varying spikes and valleys of force.
"But an engine dyno measures torque!" I've yet to see anyone correctly state how an engine dyno "measures" torque. The almost universal thought is that the dyno measures torque, and hp is calculated using rpm. (I'm talking purely about engine dynos here, quite a few people correctly understand that inertia wheel dynos are measuring power.)
It might be true that the dyno reports torque, but think about this very carefully. The engine dyno is in fact inherently measuring power. The engine's crank spins a "brake" at 100% slippage (or the engine block would be spinning wildly!). They're not like brakes we have on the wheels of our cars, but they're exactly equivalent functionally.
So picture the engine directly coupled to a brake rotor, as if the rotor were the flywheel. Then picture a fixed caliper on that brake rotor. Since there is 100% slippage between the rotor and pads, there's no direct transmission of force. What is actually happening here is that engine power is dissipated via friction in the brake, and the resultant force is measured.
In other words, What the dyno does to is measure the amount of axial force that must be applied to the caliper in order to limit the engine's speed or acceleration. We call that the torque output since, by virtue of equal and opposite reaction, the axial caliper force should equal the force the engine puts to the rotor. (Keep in mind, what's being measured in this case is the force the caliper applies to the rotor, NOT the other way around!) But the only way that force is occurring in the first place is through kinetic friction, and that means all you're really measuring is some component of energy!
Let me digress a bit and show another case where abstract thought follows real physical example:
This force peaks when the heat output and engine power output are in equilibrium, of course. If the engine is accelerating, then "torque output" measured at the caliper is lower. This is a crucial bit. Torque output is lower because you have to release the braking force on the caliper in order to allow the engine to accelerate. Said another way, if you release the caliper braking force, the axial force required to keep the caliper from spinning with the rotor drops, right? (The correct answer is "right.") So measured torque output varies depending on whether the engine is holding a constant rpm, or accelerating.
The really interesting part about the previous paragraph is that it appears to perfectly answer why measured power varies depending on the engine's rate of acceleration. This just goes to show that while torque must absolutely follow all laws of physics, it does not tell the whole story!
*** Talk about Power ***
Power: Whether Joules per second, or horsepower, or kilowatts, or whatever, Power is still just a measure of how much work is being done for a given unit of time. "Work" can also be defined in many different units. I'm going to ignore the energy lost to heat and focus on work done by the engine on the car or dyno. In this case Work is equal to the change in Energy, or deltaE. Power, then, is deltaE divided by time. Note that power is basically a measurement comprised of time and energy, when the most elemental concepts in the Universe are time, energy, and mass.
Let's examine where energy goes in a car. (Again, ignore heat from the
engine, but not from other effects.) There's kinetic energy in the rotation of the engine and driveline parts. There's energy in friction to both moving parts, and to the atmosphere (aerodynamic drag). And there's kinetic energy of the moving car itself, equal to half of the mass times the square of the velocity. Or, commonly depicted as:
KE = 1/2 * m * v^2
Ok, so lets go back to the rotational kinetic energy, and give a formula for that:
KE = 1/2 * I * w^2
This is where I (for Inertia) is a measure of how the mass is distributed in a rotating system, and w is equal to the angular velocity, or how fast the system is turning.
*** Compare Them ***
Comparing Torque vs HP: As a car's, and an engine's, speed changes, the energy changes. This energy has to come from somewhere. If speed goes down, the energy is lost to friction (heat), and work, if it speeds up the energy comes from converting the chemical energy of gasoline (or whatever fuel).
Power is a measure of how much energy can be put by the engine to the car in a given amount of time. So more power means more energy can be converted in the same time interval, or, the same amount of energy can be converted in less time. (If you understand that, then it's already clear why power is the only truly meaningful measure of an engine.)
Theoretical is all well and good, but here are some examples with hard numbers to illustrate the difference between torque and horsepower.
For the first example, consider a car with 500ft-lbs of flywheel torque when running at 3400rpm. Consider, in comparison, a second car which only makes 300ft-lbs of flywheel torque, but spinning at 6000rpm. The two cars are side by side, going equal speeds, the first car is at 3400rpm, the second car at 6000rpm. What happens? Which car wins?
There are a few things we can do in order to ease the calculations. First, since torque is ft-lbs, we can make the tire's radius one foot, so there's no gearing ratio multiplier. This means the force at the tire, in pounds, is equal to flywheel torque times the transmission ratio times the final drive ratio. We need to calculate the gearing in order to determine the force at the tire. (Take careful note that this step is mandatory.) Let's assume the car is traveling at 40mph.
If the radius of the tire is 1ft, then the circumference is:
2 * pi * 1 = 6.2832ft
So, to go 40 miles, the tire turns:
(40miles) * (5280ft/mile) * (1revolution/6.2832ft) = 33613.4 revolutions
If we go 40 miles in one hour:
(33613.4revolutions) * (1 hour / 60 minutes) = 560.2 rpm
Now we can calculate the overall gearing, since we know both the tire rpm, and the engine rpm:
Car1: 3400 / 560.2 = 6.07:1
Car2: 6000 / 560.2 = 10.71:1
(Do you see where this is going?)
Ok, so now let's see what the force at the tire's contact patch will be for each car:
Car1: 500 * 6.07 = 3035lbs of force
Car2: 300 * 10.71 = 3213lbs of force
The acceleration is equal to the force divided by the mass. Let's assume a mass that makes the numbers pretty, so 3035lbs. So, acceleration:
Car1: 3035 / 3035 = 1g
Car2: 3213 / 3035 = 1.06g
Now, let's take another approach entirely. I'm going to do it all from the perspective of horsepower, and see what happens. I may have to make some of the same assumptions, but I'll see how much calculating I can drop and still get a number. We need the horsepower numbers, of course, but my aim is to show the difference between knowing torque, and knowing horsepower. So we can't count this next calculation as part of what I need, since I'm assuming we'd have the horsepower numbers to begin with.
Car1: 500 * 3400 / 5252 = 323.7hp
Car2: 300 * 6000 / 5252 = 342.7hp
Ok, here we go:
Power = Work / time
Work = Force * distance
But, time divided by distance is equal to speed, so:
Power = Force * speed
Or:
Force = Power / speed
Wow, that's nice. All I need is the power, which I know, and the speed, which I also know! But, the problem is units. Again, we assume we know the conversion factors, so it's not something extra we have to calculate. For instance, in the Power equation, it's in Joules per second (and 1 J/s = 1 Watt). The speed is in meters per second. The force is in Newtons.
40mph = 17.878 meters / second
327.7hp * 745.7watts/hp = 241383 joules / second
342.7hp * 745.7watts/hp = 255551 joules / second
1lb force = 4.448 Newtons
Car1: 241383 / 17.878 = 13502 Newtons = 3035lbs
Car2: 255551 / 17.878 = 14294 Netwons = 3213lbs
There you have it. I won't even bother calculating the acceleration, since the forces came out identically to the first set of calculations.
I didn't have to know the rpm, or the gearing. I knew the hp, and the vehicle speed, and I told you what the accelerative force is. Horsepower turns out to be a very real, very defining term to explain and predict vehicle performance. Knowing torque, I also had to know the rpm, and the overall gearing, before I could calculate a meaningful performance figure.
Note that rpm has time in it, so I had to add the time dimension before torque was meaningful. (Remember what I said earlier?) Also, note that the flywheel torque did not translate to vehicle acceleration. All by itself, flywheel torque ends up being meaningless, otherwise the car with more torque would have accelerated harder.
From this illustration, it should be clear this holds up regardless of the car's gearing. So whether you compare cars of different or equal gearing, the one with more hp at a given speed will accelerate harder at that given speed. So the trick is to have a car with more horsepower at every point being used. Or, more realistically, optimize such that the rpm vs time maximizes the area under the horsepower curve. (Either a little more time at much higher hp, or a lot more time with a little more hp, however you can visualize what I mean by maximizing area under the power curve.)
Now, there is one phenomenon which is built into everything we just calculated, but which might not be immediately obvious. This is an important distinction, in case you glossed over the nitty-gritty above: The horsepower determines the acceleration only at a given speed. If you change the speed, it's a different rate of acceleration. Keeping power constant at 328hp means the car will actually accelerate less and less the faster you go, even ignoring friction and aerodynamics.
This is how both F = m*a and Power = Work / time are both true at the same time.
Lastly, let me point out that all industrial engines are rated only in hp. This is because industry and engineers know that only power has any meaning in determining the work the engine is capable of.
-michael
Brilliant.
Larry
code5coupe
(feeling particularly antagonistic today...)
If this is truly the case, don't you think that the automakers would be taking advantage of this fact and CVTs would be a way of life by now?
CVTs have other issues, but that's a different topic. i don't think that technology is "ripe" yet.
-michael
"Now, what does all this mean in carland?
First of all, from a driver's perspective, torque, to use the vernacular, RULES :-). Any given car, in any given gear, will accelerate at a rate that *exactly* matches its torque curve (allowing for increased air and rolling resistance as speeds climb). Another way of saying this is that a car will accelerate hardest at its torque peak in any given gear, and will not accelerate as hard below that peak, or above it. Torque is the only thing that a driver feels, and horsepower is just sort of an esoteric measurement in that context. 300 foot pounds of torque will accelerate you just as hard at 2000 rpm as it would if you were making that torque at 4000 rpm in the same gear, yet, per the formula, the horsepower would be *double* at 4000 rpm."
So, in my example, a 300 ft-lb @ 2,000 (114 hp) rpm engine with proper gearing should out pull the 250 ft-lb @ 6,000 rpm (286 hp) engine because the transmission could always keep the engine at peak torque. As such, it would make no difference at what speed the torque is produced, only that there is more avaliable. This being the case, the persuit of high rpm torque (and horsepower) is unwarranted..., assuming that you buy into the premise that it is the torque and not the power that really accelerates the car.
For maximum performance you would design the CVT to put the engine at maximum horsepower not maximum torque!!!!!!!
The 286 horsepower engine would blow away the 114 horsepower engine...
A CVT that allows the engine to stay at the maximum horsepower rpm would in fact be the ideal transmission....
This is why a broad flat torque curve is good, because the acceleration will be constant from minimum to maximum rpm in each gear.......the missing key here is the importance of gearing......
With proper gearing maximum horsepower gives you maximum acceleration.....
Ultimate transmission would be CVT that keeps the motor at maximum horsepower..
So, who is correct?
