I need some advice. I'm planning on installing a mild cam to my 85 vette. I got headers with 2 1/2 " pipes straight to the back , no catalitic, flowmasters, 24 pds. injectors, k&N with open lid filter, power chip. What will be the right application for a mild cam, do I need to replace valve springs, lifters ? I just refurbished the heads. Any feedback ?
http://store.summitracing.com/partde...5&autoview=sku
Just be sure your springs are capable of .470 lift. I have this cam/lifters in my super rammed 355 and it is a nice steet cam.
You will need new lifters with any flat tappet cam change.
Here is the cam I ordered for the 383 I built for my 72 3/4 truck. I was told it was a good match for my ported factory heads, and a TPI that I'm considering running. It may require a little more spring than the 262 Comp though. That said, there's nothing wrong with the 262 Comp either.
Need more to go on, what are the plans for the engine as far as the intake goes....are you staying stock-looking or upgrading to something else...what are the power/ET goals for the car....etc.
I staying stock, I just want the choppy cam noise.
