Opti Spark Question
Old Sep 16, 2006 | 11:18 AM
HG's Avatar
HG
Default Opti Spark Question
Before I bought this 93, the prior owner had a GM dealer replaced the opti spark distributor on 2-16-05 which failed due to a water leak on the pump. Hard to believe, I know Question, the dealer installed a part # 10457702 distributor. How could I tell if this was the upgraded or vented one, or just an exact replacement for the original non vented one.
Old Sep 16, 2006 | 11:23 AM
STL94LT1's Avatar
STL94LT1
To upgrade the opti to the 95/96 version. The dealer would have to change the timing cover, opti, opti wire harness, opti vacuum harness, and the camshaft's dowel pin. It would be a vey expensive upgrade to be done at a dealership.
Check your intake bellows for a vacuum line.
Old Sep 16, 2006 | 11:28 AM
HG's Avatar
HG
OK , thanks I;m sure it was a direct replacement. Also, where is the vacuum line.
Old Sep 16, 2006 | 11:53 AM
IRAraid's Avatar
IRAraid
Default Optispark vent line
Tried to post a pic but the 'system' won't allow it (must be a neophite).
The vent line is a small black hose with a gray elbow attaching it to the top of the 'bellows' air inlet hose, just about even with the alternator pulley.
Old Sep 16, 2006 | 09:59 PM
Bruce's Avatar
Bruce
I run Delteq on my 93. Glad I did. i like it. The 92/93 opti is way to expensive. The 94-96 are much cheaper but required to change timing cover and cam shaft dowel pin. The delteq is far better than any GM and aftermarket opti. The delteq don't need to MSD box to add extra energy to the spark plugs. As obvious its multi coils pack.
Old Sep 17, 2006 | 07:59 AM
Tom Piper's Avatar
Tom Piper
In order to put the later vacuum vented Opti-Spark on my '92, along with the other parts mentioned above, I had to change the camshaft.
The early LT1 camshaft does not have a center-hole in the front that is big enough for the later Opti-Spark to fit into.
Tom Piper
Old Sep 17, 2006 | 02:45 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
You can vent an early Opti-Spark yourself.
http://www.corvettefever.com/howto/16758/
Old Sep 17, 2006 | 05:12 PM
tjwong's Avatar
tjwong
That part number is the early version.
To Opti Spark Question
