Coolant Temp Sensor
Old Sep 19, 2006 | 09:27 PM
fjm59vette's Avatar
fjm59vette
Default Coolant Temp Sensor
Does the Coolant Temperature Sensor mounted in the front of the block send signals to any component that would control engine idle and performance, timing etc.
I notice that this sensor was oose and my digital coolant guage was reading temperature all over the place. From 198 to 140 to 40 to LO. Every time it did while at normal operating temp (198) the engine missed and bucked - like the timing was off. At one point it even stalled, and wouldnt start. Then when I jiggle the wires at the temp sensor connect and was able to stabilze the temp reading to nrmal operating temp. the car started and ran fine.
Its loosened up on a few more occasions and when it does the temp readings go wild and the car runs rough, play with the wires and stabilize it and the car runs fine.
So does that sensor send info to ECM, ICM, Opti or any other engine management system that could produce inefficient operation, missing or stalling?
Please advise
Frank
Old Sep 19, 2006 | 09:35 PM
RRT vette's Avatar
RRT vette
Please advise
Frank
Yes, ECM
Old Sep 19, 2006 | 11:49 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Yes as stated. The ECM uses it to control a crapload of stuff
But, it has no relationship to the temp gauge, it only feeds the ECM info. I'm not familiar with the 90's and newer vettes , but thats the case for 84-89
Old Sep 20, 2006 | 06:01 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Yep, its the same on the later ones, but there is 2 sensors(92-96). One for the analog dash guage, and the one in the water pump is the important one
P.S. Fjm59vette, we can always help you much better if we know abit more about your car!!! (i only took a wild guess that is a 92-96)
Old Sep 20, 2006 | 11:54 AM
CFI-EFI's Avatar
CFI-EFI
In an L98 the ECT sensor is in the front intake manifold. I don't believe any of the C4s have temperature senders in the block, anywhere. Other senders or switches are located in the heads.
RACE ON!!!
Old Sep 20, 2006 | 12:16 PM
Casethecorvetteman
RACE ON!!!
Its a gamble at what engine he is talking about really isnt it. He doesnt tell us or give us a year model, which makes life hard. Since he says words like "opti" im going to guess he has an LT1 and he thinks the water pump is part of the block. Either way, all areas are covered!!
Old Sep 20, 2006 | 12:27 PM
pcolt94's Avatar
pcolt94
As stated knowing what kind of car you have would take lots of guess work out of it. But if you do have the sensor in the water pump up front, it does feed you temp gauge and as said, inputs to your ECM. It is a MAJOR player in the A/F mixture calculations that the ECM performs especially in open loop operations.
As the engine temp goes up, the resistance of the sensor goes down hence telling the ECM to go leaner. If the sensor is open, wires broken or connection corroded the resistance will go higher (much higher) and tell the ECM to go real rich because the ECM thinks the engine is cold.
Old Sep 20, 2006 | 02:03 PM
redrose's Avatar
redrose
MANY of these CTS units are off calibration, even though not fully failed...check yours with a scanner when cold and with the engine at operating temp...many, many minor performance problems are the result of an inaccurate signal from the CTS to the ecm
new CTS units are cheap...both price and quality...MUST check with a VOM vs tables in the fsm prior to install (i've seen several brand new ''junk'' ones)
Old Sep 20, 2006 | 06:44 PM
CFI-EFI's Avatar
CFI-EFI
And by his user name, fjm59vette, it doesn't even look like it is a C4. Maybe it's a transplant. But if so, what into what?
RACE ON!!!
Old Sep 22, 2006 | 10:09 AM
fjm59vette's Avatar
fjm59vette
Default definately a C4
RACE ON!!!
Guys Sorry - Yes imine is a 1994 LT1 6 Spd Polo w/Greenwood Kit. And most definately the Coolant Temperature Sensor does send info to a system component that affects engine operation, believe me it does, because the thing is loose and and when the temp gauge goes wild the car operates erratically !!! will even stall !!!!
Old Sep 22, 2006 | 10:10 AM
fjm59vette's Avatar
fjm59vette
Default Reply
Sorry - 1994 LT1 6Spd
Old Sep 22, 2006 | 10:18 AM
fjm59vette's Avatar
fjm59vette
Default Its gotta be the sensor in the Water Pump
I said front of block - sorry I didnt realize it was mounted in the water pump. But thats the one. It definately send the info to the digital coolant temp guage cause thats the guage that goes wild, not the analogue one.
I have to replace it !!!! Do I have to worry about coolant draining all over the place when I do ?
Old Sep 22, 2006 | 10:27 AM
RRT vette's Avatar
RRT vette
Yes, the ECM. The ECM uses this sensor to contol engine idle on startup and fuel trims, ect.. If the connector is loose or the sensor is faulty it will cause all sorts of drivabilty problems. Apparently there are two different sensors for the LT1 as is for the L98. In the L98 (not certain of the 84 and 85), there is a Coolant temperature sensor in the front of the intake manifold that sends engine temperature to the ECM due to changes in sensor resistance and there is a Coolant temperature sender in the right cylinder head that sends engine temperature to to the dash guage. On the LT1 the Coolant temperaure sensor for the ECM is on the waterpump. Not sure where the guage sensor is, but is should be in one of the heads.
All an overview of what has already been stated.
Old Sep 22, 2006 | 10:53 AM
Casethecorvetteman
Yes mate, this is the one the ECM sees, the other one only goes the the analog gauge, the digital gauge gets it signal from the ECM. Coolant WILL **** out that hole as soon as you remove it, and if i were you, id drain the system before you remove it, so this way you wont get anywhere near as much coolant come out of the hole.
Old Sep 22, 2006 | 03:31 PM
IrishJoker's Avatar
IrishJoker
I have had a question about the coolant sensors as well - answer me this - does the snesor which sends information to the ECM also send it to the digital display on the dash? I have both an analog and digital readout for coolant. Right now my analog gauge doesn't work but the digital readout is fine.
For you LT-1 owners - where exactly are these 2 sensors located? Anbody have a good picture?
Old Sep 22, 2006 | 06:27 PM
pcolt94's Avatar
pcolt94
FYI:
94 & up is a PCM
93 and down is a ECM
Your analog sending unit is on the drivers side between the last two cylinders (5 & 7) in the head. It only drives your analog gauge.
JFM - Just update your profile with your car info, its easy.
Old Sep 23, 2006 | 12:17 AM
kittmaster's Avatar
kittmaster
Yes, ECM
And digital display data gauge
To Coolant Temp Sensor
Old Sep 25, 2006 | 02:38 PM
fjm59vette's Avatar
fjm59vette
Default That sensor does send to digital guage
The sensor on the water pump definately does send the temp to the digital temparature guage on the dash. The only reason I knew the sensor was faulty was due to the crazy temp reading given to me by the digital coolant guage.
Old Sep 26, 2006 | 08:44 AM
mikey's Avatar
mikey
FYI, if your gauge on your '94 is changing temp reading erratically, then it is likely the wiring or connector. An open circuit will cause it to read LO.. I had this same problem on my '94, but luckily the bad portion of the harness was near the connector so I just had to replace the end of that pigtail..
The temp reading shown on the digital readout is the same one the ECM is using and it controls fuel.. when it thinks it is cold, it'll dump a lot more fuel, causing your "misfire" feeling..
Email me if you have any more questions, I don't check these boards that often..
Hope this helps,
Mikey
Old May 19, 2013 | 01:23 PM
melthom's Avatar
melthom
2021 C4 of the Year - Unmodified Finalist
Thanks for this post. It answered my question that some mechanics could NOT answer. I went to a car show on Saturday. Car ran fine, but on the way home the digital coolant was bouncing all over the place. Pulled into a parking lot and the engine died. Few minutes later it fired up like nothing was wrong. Read your post, was going to pull the sensor out and check for corrosion, BUT as soon as I touched it half of it fell out in my hand.
Thanks again...... 1996 LT1
