Little bubbles???
Old Sep 21, 2006 | 11:13 AM
aminnich's Avatar
aminnich
Originally Posted by Casethecorvetteman
Yep, small one going from top of radiator to surge tank. It did it from cold start right up to about 60-70*C. Does yours do it too??
I have seen the tiny bubbles once or twice that I remember, but rarely take the surge tank cap off. I am very, very sure that I do not have any engine problems and do not worry about the occassional tiny bubbles. I just attribute it to cavitation or for some other reason a minut amount of air is in the coolant, either trapped or from agitation.
Whatever, I don't let it agitate me.
Old Sep 22, 2006 | 08:38 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Roger that Aminnich, i dont really want to pull the heads off my engine, but any reasonable excuse and ill be in there like a flash.
Old Sep 23, 2006 | 10:57 AM
Slalom4me's Avatar
Slalom4me
Check for the equivalent of the 'Lisle 75500 Combustion Leak Detector'.
Like the link says, you measure some of the magic fluid into the
wand, attach it to a vacuum source and then hold the inlet end
over the radiator cap opening or other suitable access point to the
coolant. If the colour changes, then you have cause for concern.
Check with your neighbor, Stingraynut. He has been through this
and can hook you up. Might have signs of blown head gasket now
You might also want to search out oil analysis labs. It isn't costly
to have samples tested and this will show whether coolant is getting
into the bottom end.
Old Sep 23, 2006 | 11:43 AM
Casethecorvetteman
Thanks mate, im still waiting on getting a chance to have it tested yet. Ive ordered a testing device from a mate in Colorado, but there is other things in the order and it wont be sent yet so ill still be a few days off.
Old Sep 25, 2006 | 08:55 AM
Casethecorvetteman
**** out of luck here, head gasket is blown somewhere.... Had the test done today by a local mechanic shop that does free inspections and the liquid changed colour within 10 seconds....
Thanks again to all those who replied and offered advice
Old Sep 25, 2006 | 11:22 AM
Slalom4me's Avatar
Slalom4me
Au contraire, mes ami.
You diagnosed the problem before it took out your bottom end. Very
lucky and a great benefit to your budget. Many, many others here
have not been so fortunate.
Some labour, some gaskets and you could be back in business.
Alternatively, you could throw the money you just saved at the
car in the form of maintenance and performance parts.
Nice work.
Old Sep 25, 2006 | 11:26 AM
Casethecorvetteman
Ill be doing all the labour myself mate so ill save a fair chunk there!! Still no sign of any water in the oil.
Slalom4me's Avatar
Slalom4me
Odd to see head gasket issues occur on a '94, though. The L98's
with alloy heads have been chronic offenders.
Do you use glycol and distilled water?
Old Sep 25, 2006 | 12:09 PM
Casethecorvetteman
I do yes, i dont know what the previous owner used though, looked alot like straight water full of rust when i bought the car. I have changed it a fair few times since ive had it and the last 2 lots of coolant have stayed looking perfectly clean with nothing visible floating in the system, and perfectly clean coolant in the overflow tank.
