Cross utilization? Plenums
Old Sep 20, 2006 | 11:08 PM
Iemtall's Avatar
Iemtall
Default Cross utilization? Plenums
Was curious if the plenum and runners off a 87 chevy 305 are the same as on a 87 TPI 350 vette? Also, what about the manifold base? Appreciate any input! Thanx!
Old Sep 20, 2006 | 11:10 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Yep.
Old Sep 20, 2006 | 11:12 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Wait!!! I changed my mind!!!
The RUNNERS off the 305 will be MUCH easier to polish up than the cast Corvette runners.
Fuel rails ... DIFFERENT.
Otherwise, samo, samo.
Old Sep 21, 2006 | 09:29 AM
KENS80V's Avatar
KENS80V
Manifold base is different too. Center two mounting bolt holes on either side are drilled at a different angle on the Camaro/Firebird manifold. Also the EGR systems are not compatible. The plenum extensions are different too. Corvettes are aluminum while the other type is plastic.
Old Sep 23, 2006 | 07:29 PM
85C4Man's Avatar
85C4Man
i was wondering the same thing and with some google searching i found this site http://www.hotrodlane.cc/Streetstories/choosingtpi2.htm it gives great info on the differences
To Cross utilization? Plenums
