TPS Settings
Old Sep 22, 2006 | 01:37 PM
wro87's Avatar
wro87
Default TPS Settings
Does any one now what the optimum setting would be for a TPS on a 58MM throttle body would be we have this on a 89'L98 (that has been built up a little) that we have installed in a 87' roadster. Thanks wro87
Old Sep 22, 2006 | 05:58 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Regardless of the fact that it's an aftermarket TB, the values would still be within the ranges listed in the factory manual for your particular car.
Old Sep 22, 2006 | 06:09 PM
RRT vette's Avatar
RRT vette
The ECM see the voltage the TPS is set at and it shouldn't matter when the TB is changed. I should be around .54v at closed throtte and at least over 4.0v WOT with a smooth increase in voltage as the throttle plates are slowly opened.
Old Sep 22, 2006 | 06:15 PM
Corvette Kid
It sounds as if it's close to the values of the LTx engines then. .3-.9v at idle and about 4.5v (I believe) minimum with closer to 5v being ideal. If you have a scanner and it shows 0 at idle and 100% at WOT, you should be good.
Old Sep 22, 2006 | 09:32 PM
scorp508's Avatar
scorp508
Your particular L98 ECM wants ~0.54V at idle and over 3.45V at full throttle. The stock ECM program dictate that over 69% of reference line voltage (which is 5.00V) is considered WOT.
Old Sep 22, 2006 | 10:54 PM
wro87's Avatar
wro87
Thanks guys I wasn't real sure if it was the same! I have had the ecm reprogrammed and will hook up a volt meter then will try a scanner. wro87
To TPS Settings
