Plug wire question.
Old Sep 22, 2006 | 03:44 PM
Bob88Convertible's Avatar
Bob88Convertible
Default Plug wire question.
Anyone using these? Any opinions? Whats everyone using?
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 23, 2006 | 03:05 PM
Bob88Convertible
Anybody???
Old Sep 23, 2006 | 03:35 PM
DanZ51's Avatar
DanZ51
I have used those (Blue Max) in the past. They were OK but after three seasons I had leaks. Even though the resistance checked within spec for each wire, voltage was shorting out on the Air Injection tubes causing a misfire. In the dark you see the sparks jump.
I currently use MSD wires. I also get the HEI universal set and cut to my own wire lengths. I never could find a wire set (even AC Delco) that would fit well.
Old Sep 23, 2006 | 04:08 PM
xflagz51's Avatar
xflagz51
Check this web site out, www.magnecor.com, this site will tell you everything you always wanted to know about spark plug wires.
Old Sep 25, 2006 | 11:56 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Yes,they are good wires, no fads or gimmicks. My set has lasted over 50,000 miles with no problems.
Old Sep 25, 2006 | 12:04 PM
Bob88Convertible
Thanks, lots of good info there.
Old Sep 25, 2006 | 12:28 PM
rick lambert's Avatar
rick lambert
I've had good luck just using the Belden wires from NAPPA, perfect length and I think they were around $45.
Old Sep 25, 2006 | 04:43 PM
Davemc1963-87conv's Avatar
Davemc1963-87conv
I use the Blue Max wires with a Performance Distributors HV coil, module, rotor and cap. No problems yet.
Dave
Old Sep 25, 2006 | 07:07 PM
gslotman's Avatar
gslotman
I agree with Macthlight and Danz51 - you cannot go wrong with magnacor or MSD
I'm runnnig MSD 8.5 super conductors (with 6A box and coil).......
Old Sep 25, 2006 | 08:12 PM
Lone Ranger's Avatar
Lone Ranger
I am currently running the 8mm Moroso Blue Max wires on my '95 with good results.
To Plug wire question.
