Bilstein Shocks - Stupid Question
Old Sep 23, 2006 | 11:06 PM
OldCorvetteFan's Avatar
OldCorvetteFan
Default Bilstein Shocks - Stupid Question
I just got a set of Bilstein shocks from VB&P for my '95. I bought the Bilstein Sports (Z51 valving) instead of the Bilstein HD shocks based on my discussion with VB&P about my driving style (and my local roads).
I took all four out of their boxes (they sent me the wrong set the first time).
Here's the dumb question - why can't I move 'em???
Are these suckers so stiff that a mere mortal can't compress or decompress them? I push, I pull - and its like pushing or pulling a chunk of steel! Is it due to the gas pressure? I've only dealt with "regular" shocks for my other vehicles.
I'd prefer to solve this little puzzle before I put them on the car and find out that there is a 'secret handshake' routine that should have been followed prior to installation!
Thanks,
Steven
PS - If this is the intended operation, I guess the car will really handle like a go kart!!
Old Sep 23, 2006 | 11:23 PM
bogus's Avatar
bogus
and ride like a truck....
however, a new shock will not compress by hand very easily. I put KYBs on my wifes 87 a couple weeks ago, and they would not move, unless I sat them on the pavement and put my 265lbs on them.
Old Sep 23, 2006 | 11:43 PM
LS6 Motor's Avatar
LS6 Motor
265 lbs......daaaamn, time for Momma to put a timed lock on the refrigerator door
Old Sep 24, 2006 | 12:01 AM
creoleman's Avatar
creoleman
Yeah, but he forgot to mention that he's eight feet tall.
Old Sep 24, 2006 | 12:05 AM
OldCorvetteFan
Sounds like there's no surprise that I can't move 'em by just squeezing them together, then.
OK - I'll see what happens if I push using my body weight...
Thanks!
Steven
Old Sep 24, 2006 | 12:31 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Now, don't forget to tell us how the car rides, then how it handles, and finally how it sounds (if there's any change in that; probably not tho). I presume once you put them on, they're yours. But you still might like to keep the old ones around vs. throwing them out.
Good luck, Steven!!!
Old Sep 24, 2006 | 07:49 AM
OldCorvetteFan
Right now I'd say the car rides very welll - a buddy of mine picked up an '87 coupe with the Z52 package, and in back to back rides over the same roads, a third buddy gives the nod to mine in ride.
Handling, though, is a bit different. The Z52 car is more "go kart" like, while mine seems more content to plough around corners. My seat of the pants comparison between his Z52, my '95, and another guy's '02 SS Camaro has the Z52 a clear winner, and my '95 and the SS close.
The other thing that decided it for me really occurred prior to any handling tests - when I got the car, I cleaned up the front suspension as betst I could. In my periodic inspections, I'm seeing a build up of accumulated oil/dirt (combining to look like grease, but it's not) at the base of the shocks (both sides). This isn't the expected oil film that the FSM discusses - its coming from the piston area, running down to the mount, and collecting dirt and dust. So, time to change!
I'm planning to document the procedure, and I'll certainly report back what differences I feel. I'll also keep the old ones for the next owner (I already have a big plastic box for old parts!).
Steven
Old Sep 24, 2006 | 08:30 AM
OldCorvetteFan
Default Problem Solved!
I have now added new knowledge to my Corvette data bank -
When you get your new Bilsteins, put them on the floor, and push them down with all your might. You will hear a little 'gurgling' sound, and then voila! the shock will move! It isn't easy, but it does. Once you get past the initial gurgling noise, then it is easier. I exercised each shock about ten strokes (full travel), and now I can skip my next workout!
I wonder if this explains some of the "ride height" change issues that have been posted in other threads. I'll take ride height measurements before and after and see if there's a difference in mine.
Thanks for all the help!
Steven
Old Sep 24, 2006 | 03:53 PM
lefoy84's Avatar
lefoy84
This may sound obvious, but they usually come compressed and held that way by some kind of strap that must be removed.
Old Sep 24, 2006 | 04:38 PM
resipsa's Avatar
resipsa
My base suspension 95 came with flacid Bilsteins. I dont recall them being very difficult to compress and they had very little resistance in rebound (I replaced them with Koni sport adjustables in early 1996).
However, back a longggg time ago I purchased Bilsteins for my then brand new 79 Firebird WS6 Trans Am. The base shocks did not do a good job of controlling the solid rear axle so I tried the Bilsteins. I remember them being extremely difficult to compress also. They cured most of my concerns with the solid rear axle and they noticeably increased the ride height of the car, especially in the rear. This was OK, however, as the rear leaf springs in those 2nd generation F-bodies tended to sag over time giving the car an undesirable(IMO) backwards rake.
Old Sep 24, 2006 | 04:51 PM
OldCorvetteFan
Nope - the set that came were in the box, with no straps. The prior set (the wrong ones) also didn't have any straps.
Even I would have noticed a strap (or some other external object) holding the shock in compression. I'm just glad that I tried Andy's recommendation with my full body weight!
Steven
Old Sep 24, 2006 | 08:11 PM
Lone Ranger's Avatar
Lone Ranger
I've thought about installing the Z51 Bilstein's on my '95 also. I'm very interested to hear how this works out.
Old Sep 25, 2006 | 07:44 AM
runner140*'s Avatar
runner140*
I guess my 152 lbs wouldn't do.
Old Sep 25, 2006 | 09:04 AM
Aardwolf's Avatar
Aardwolf
I just installed Bilsteins to, no problems installing other then not being able to torque the top nut. It doesn't reach what the book says before the rubber bulges way out. So I set it so that the bushing looks tensioned. I didn't try to excersise them, it'd be my luck I'd bend it. No ride height changes.
Old Sep 26, 2006 | 04:23 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default shocks
I installed bilsteins om my 86, and they had plastic restraints on the shocks. But:
in the meantime, I got some used KYB, monroe, bilstein, and what looked like (don't laugh) sears shocks (maremount shocks)
out of the junk yard to try different ones to see how I liked them.
The Kyb were really stiff and the bilsteins were firmer than my originals.
The sears ones were just like the monroes, kinda like my originals.
Don't know if that helps, but I only spent 40 bucks cause they only wanted 2.50 for "used" shocks and they let me pick and choose what ones I wanted, and cause I had so many in the milk crate.
I picked ones that looked fairly new with what appeared to be almost new bushings on them.
I kept the KYB shocks because they were stiffer than the bilstiens, and if I get a wild hair, I put them on, and race around a little, and put the bilsteins back on cause I'm a wuss and like a better ride.
Old Sep 26, 2006 | 04:27 PM
coupeguy2001
Default shocks
OH BTW,
I had a machine shop machine upper shock mount biscuits out of polyeurethane because the rubber bushings took up most of the movement, and the shocks seemed lazy.
It firmed up the ride a tad, but it seemed to respond better to corners.
Oh btw,
I replaced my hollow sway bar with a solid bar out of an 84 and now it CORNERS!!
To Bilstein Shocks - Stupid Question
