More Hose Questions...
Also there are three fittings on the passenger side of the throttle body. One is for coolantand I will bypass this, I assume this is the long one on the bottom, another is for the PCV system, while the third confuses me.....
Yet another problem is alot of vacuum hoses... I have the Gm manual, but cant really locate any pictures of where the hoses go. I have three vaccum fittings by the fuel pressure regulator in the intake plenum, one for the MAT sensor, one for the regulator, what about the third? Ill have more later....
Paul
God Bless those that lost there lives Tuesday....
as a side note there is also another much smaller rubber hose which is right next to this hose. The much smaller hose plugs into the drivers side of the throttle body, on the bottom. It has 2 pieces to the tube as well, just like the first one I described.
One goes to the fuel ragulator.
the last one goes to the EGR solenoid which I think you are going to try and remove? cap it.
[Modified by bill mcdonald, 1:44 AM 9/16/2001]
