Strokermotors.com?
Online Specials
Special 383 Short Block
$2,995.00
This special offer consists of a fully prepped late model 4 bolt main, 1pc rear main seal roller block that has been decked, bored & honed with torque plates. The rotating assembly consists of a DES 4340 nitride treated steel 3.75" stroke crankshaft, a set of DES 4340 6.0" H-beam rods, Clevite 77 cam bearings along with race rod and main bearings, a set of Probe 2618 alloy 9.83:1cr @ 64cc forged pistons and a set of Speed Pro plasma moly rings. The kit was precision balanced to +/-1 gram and professionally assembled by the folks at Strokermotor.com.
If you already have a camshaft, timing set, a set of heads, oil pan and all of the other bolt on parts needed to complete the build, this piece is for you.
Give us a call at 214-350-4979 or email us at info@strokermotor.com.
Anybody ever done business whith these folks? What's your opinion of this motor?
I called them and talked to them when I was looking at getting a motor built, and the reason I didn't go with them, is they were waiting 6+ weeks for AFR heads, and I didn't want to wait that long.
Give Harold at Port Pros in Tx. a call. If you want to know about his engines, go to Forced Induction and look up tread happy camper. See what Greg from Blowerworks has to say. Harold built my engine. portpros.com
