Brake Failure
Old Sep 26, 2006 | 09:10 PM
pcolt94's Avatar
pcolt94
I have just recently just done some tests on boosters on the vette and some other of my cars also. You can believe the difference in braking when the booster gets no vacuum or has catastrophic failure. If performs nothing like a weak or leaky booster, I have had them.
If the booster has no vacuum or fails there are almost no brakes and I was ready for this situation, I set it up. You could not drive in traffic. If it caught you by surprise and it failed big time, you would not have the reaction time to use both feet and all your power to stop the car. When I set it up I was ready and was really surprised at the drastic difference in performance.
Old Sep 26, 2006 | 09:16 PM
Da Mail Man's Avatar
Da Mail Man
....how did your brakes work today after your abs changeout?
Old Sep 26, 2006 | 09:19 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Originally Posted by Davesvette94
The knee was just part of it I spent 2 days in Shock Trauma. Broken Left arm (plates, pins & screws), Fractured Sternum & several right side ribs (from belts), Face looked like I made George Foreman mad (airbag).
The good news is: I'm still here. The car did her job!! She crushed where she was supposed to, bags & belts did their job. The low seating position saved me from head injuries.
This car went over a 50-100' cliff, then collided head on with mother earth and flipped on its roof. In a lesser car and without the help of the MAN ABOVE I wouldn't be here!
Holy crap! it gets worse?? off a 50-100 foot cliff? my god. you are one lucky person to be able to post, at all!
Old Sep 27, 2006 | 12:24 AM
Goldcylon's Avatar
Goldcylon
Default re:Yikes
Now thats plain ugly, glad to see your still around.
Old Sep 27, 2006 | 11:01 AM
Kinkajou's Avatar
Kinkajou
What basic tests would someone sugest to try diferentiate from a master cylinder failure or a booster failure?
Old Sep 27, 2006 | 11:44 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Not luck, he was BLESSED! No doubt about it in my mind at all!
Old Sep 27, 2006 | 12:49 PM
bogus's Avatar
bogus
Dave - get a pro to check your car... he needs to test the boosters capacity to hold vacuum.
We here on the forum are well aware of this on-going problem with the C4 vacuum boosters, and from my perspective, it's inexcusable.
If the booster has failed, then report it to the NHTSA. If enough people are forced into complaining, then perhaps something will be done about this.
Old Sep 27, 2006 | 02:09 PM
bogus's Avatar
bogus
Very simple - cause and effect.
When a master cylinder fails, it loses all internal pressure. The pedal falls to the floor.
When a booster fails, it loses all internal pressure... and the pedal barely moves.
