1995 corvette motor
Old Sep 28, 2006 | 06:09 PM
hezi's Avatar
hezi
Cruising
Default 1995 corvette motor
I have put a 1995 corvette lt1 motor in my 1939 Ford.
Problem is it will not run for more than 5 secs.
Anyone have an idea what`s wrong??
Old Sep 28, 2006 | 06:13 PM
7thvet's Avatar
7thvet
Oil pressure switch?
It has to have oil pressure or it'll shut off.
Just a guess.
Old Sep 29, 2006 | 11:03 AM
hezi's Avatar
hezi
Cruising
oil pressure is 62psi
Old Sep 29, 2006 | 11:20 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
It could be so many things
You need a service manual to trouble shoot this
Does the fuel pressure hold steady after it shuts down?
The fuel pump comes on to start the car then if it doesnt see oil pressure it shuts it down
Still could be the problem
Can you pull codes?
Old Sep 29, 2006 | 11:28 AM
CFI-EFI's Avatar
CFI-EFI
Air, Fuel, spark and compression, all at the right time and all in the proper amount. What's missing?
Just a guess.
With all stock wiring, that is NOT true.
RACE ON!!!
Old Sep 29, 2006 | 12:33 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I had the same problem with a different car, check the fuel pump. Mine would come on when the key was turned on for 2 secs and then would cutoff till the key was turned off then on, also check the fuel pump relay and wiring.
Old Sep 29, 2006 | 12:50 PM
rick lambert's Avatar
rick lambert
Time to hook up the fuel pressure guage.But there are other things that could cause it...and like CFI-EFI said, with stock wiring the oil pressure switch will not shut it down. It's only a backup for the fuel pump if the FP relay fails.You should be able to check for constant spark even without the engine running. Those are the 2 areas I'd check first.
Old Sep 29, 2006 | 02:57 PM
CFI-EFI's Avatar
CFI-EFI
The ECM is programmed to energize the fuel pump, via the fuel pump relay, for the first 2 seconds of "key On". If the fuel pump runs for the first 2 seconds after the key is on, it proves that the fuel pump, the fuel pump fuse, and the fuel pump relay, all work.
RACE ON!!!
Old Sep 29, 2006 | 03:18 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If you are using a fuel pump for a carbed engine, it will start and die. Do you have a high pressure fuel injection fuel pump
Old Sep 29, 2006 | 08:05 PM
lefoy84's Avatar
lefoy84
RACE ON!!!
CFI-EFI is right! When the key is turned on, the fuel pump is turned on briefly. If the car is not started right away, it shuts down. The oil pressure switch is a backup to the fuel pump relay.
Old Sep 29, 2006 | 08:29 PM
CFI-EFI's Avatar
CFI-EFI
And once the engine starts to rotate, the ECM, again, closes the relay to run the fuel pump. As long as the engine is turning, whether running or cranking, the ECM energizes the fuel pump relay.
RACE ON!!!
Old Sep 30, 2006 | 10:01 AM
Atok's Avatar
Atok
Are you using the PCM that is matched to the engine? If you are then did you also install the CCM? Maybe it's FEDS (Fuel Enable Data Stream). If the CCM does not "authorize" the PCM to start the engine then the engine will only run for a few seconds and shutdown. If it starts at all.
Old Sep 30, 2006 | 10:56 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Well, it could be your muffler bearings.
We need a LOT more info that 'It Runs For 5 Seconds and Shuts Down'.
What have you got?
What's your 'TIQ' (Troubleshooting IQ)?
Did you wire it up?
Stock wiring harness?
Stock ECM?
Reprogrammed ECM?
What fuel pump?
What have you checked?
What's been proven already to be good?
Whe it runs for 5 seconds is it running ok?
There's really not enough data to do anything other than guess by gosh.
To 1995 corvette motor
