tach reads wrong
Old Sep 29, 2006 | 10:16 AM
77vetteuk's Avatar
77vetteuk
Default tach reads wrong
Is there any way to re-calibrate the tach
Car is an '91 L98 6 speed, Idle reads aound 1200 rpm on tach (checked with scanner, shows around 750 rpm)
When driving in 4th gear it red-lines at 95 mph!
Make me wonder what rpms im really shifting at when flooring it and shifting at the red line?
Whats causing this? any way to rectify it?
Old Sep 29, 2006 | 11:40 AM
jimmers's Avatar
jimmers
Its most likely the tach filter. It was a common problem from 90-91.
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Not sure but I think the service manual addresses this very thing
If I remember correctly it said something about a filter on the tach
I hate to be one to say Check the FSM but
Check the FSM
Old Sep 29, 2006 | 05:45 PM
Yellow2015's Avatar
Yellow2015
This will also happen with certain aftermarket ignition coils. I installed an MSD coil and my tach went nuts. The more gas I gave it, the lower the tach went. I went back with the OEM and all is well now..........
Old Sep 30, 2006 | 10:14 AM
77vetteuk's Avatar
77vetteuk
AH, that'll be it then-DUI cap and coil installed since i bought the car.
Had a bad tach filter on a C3,and it didnt behave like this.
Ill go back to a delco cap/coil,see if it helps.
THANKS
Old Sep 30, 2006 | 11:38 AM
Yellow2015's Avatar
Yellow2015
THANKS
Even a blind squirrel finds a nut every once in a while.
Let us know if that solves it.
To tach reads wrong
