hypertech chip question
Old Sep 15, 2001 | 02:37 PM
WhiskeyPapa's Avatar
WhiskeyPapa
Default hypertech chip question
will my vette pass emissions with the hypertech stage II chip installed?
Old Sep 15, 2001 | 02:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: hypertech chip question (WhiskeyPapa)
I just installed a "bargain" (reads e-bay) '87 HyperTech Stage II chip but haven't had a chance to test results yet. However, instentaneous mileage seems as good if not better as with the stock chip. I think this is a good indicator of efficiency and hence emissions.
If you're concerned about emissions, try my spark plug "trick" (on my site) to increase burn efficiency, upgrade your ignition system and make sure your motor is up to operating temp before you go to the emissions check center.
I don't think the Stage II chip will of itself would cause you to fail emissions.
Old Sep 15, 2001 | 04:49 PM
ROADAPPLE's Avatar
ROADAPPLE
The Hypertech Stage II chip only changes engine operating peramiters (timing & injector duration) at WOT. It also turns the fans on earlier but this shoukd not effect emitions.
Old Sep 15, 2001 | 07:53 PM
Andy1983's Avatar
Andy1983
Hypertech wont affect emmissions at all.
In fact, it COULD (very rarely) increase your mpg.
It does, in conjunction with the 160* Thermostat, make your engine run at great temps. (180-200)
To hypertech chip question
