1986 Distributor help
Old Oct 5, 2006 | 06:11 PM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
Default 1986 Distributor help
I'm trying to troubleshoot a rough running issue with my 86 coupe. I'm checking the distributor per FSm and have a question about the coil connectors.
The TACH and BAT connectors, what color are they? One is white and the other is pink. Which is which? When I changed the dist cap I may have swapped them.
Old Oct 5, 2006 | 06:28 PM
RRT vette's Avatar
RRT vette
I believe the tach is white. See were the white wire runs to. Should go to the tach filter.
Old Oct 5, 2006 | 07:32 PM
CFI-EFI's Avatar
CFI-EFI
The big, fat pink wire is the 12 volts for the "BAT" connection.
RACE ON!!!
Old Oct 5, 2006 | 08:10 PM
lefoy84's Avatar
lefoy84
I don't think you can swap them. One won't fit in the other. Anyhow. if the car won't start, you have them wrong!
Old Oct 6, 2006 | 12:21 AM
86PACER's Avatar
86PACER
Actually you can. I've done it by accident durring a head gasket reassembly.
Old Oct 6, 2006 | 09:31 AM
rick lambert's Avatar
rick lambert
Some of the coils require the use of a short metal ground strap....comes with the coil, and some have the ground wire already attached to the coil, just needs to be grounded, but it ain't gonna work without a ground. When you route the coil wires be careful, I crimped one.
To 1986 Distributor help
