Fog Lamps
Old Oct 6, 2006 | 09:43 AM
PourJim's Avatar
PourJim
Default Fog Lamps
On my '84 the fog lamps only can be on when the head lamps are on. I would like to run the fogs without the headlights up and on. Anyone ever rewire to accomplish this and if so was it a project or rather simple? Can anybody supply instructions?
Thanks in Advance!
Old Oct 6, 2006 | 11:07 AM
UWEBABY's Avatar
UWEBABY
St. Jude Donor '06-'07-'08-'09
Jim, Do A Search Under Fog Lamps, Scroll Down To The C4 Entries. There Are Quite A Few Threads There Dealing With Your Question. Goodluck
Old Oct 7, 2006 | 08:31 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Don't know if my 86 is different than 84, but i only have to pull the light switch to the running light position and then turn the fog light switch on.
Old Oct 7, 2006 | 08:53 AM
Yellow2015's Avatar
Yellow2015
If you mean you want the fog lights to be on when you use your high beams then all you have to do is run a seperate ground wire for each fog lamp.
Old Oct 8, 2006 | 12:34 AM
johnnyevans's Avatar
johnnyevans
Not exactly right. Depending on the year, it requires further mods to wiring.
Old Oct 8, 2006 | 08:07 AM
tombobbitt's Avatar
tombobbitt
Default 1984 Fog lamps
I changed my fog lamps so they would come on when I turned on the fog light switch to the right of the headlight ****. It required removal of the dash pad in order to ge to the wiring but it was worth the effort. I also changed the bulbs so that they are brighter. I can now run just the fog lights at certain times and they light up the road as well as the headlights.
I am currently in Charlotte and will not be back home for a week but if you want to send me your address, I will mail the info to you about how to do all of this. If you have any mecanical ability, you will be able to do it. My email address is tombobb@verizon.net.
To Fog Lamps
