AFR Heads again!
Old Oct 10, 2006 | 02:18 PM
Red Tornado's Avatar
Red Tornado
Originally Posted by bill mcdonald
I have AFR 190 heads, and a high volume oil pump on mny L-98
I have the same issues. 100 mile drive, oil is low.
in the spirit of the OP, has anyone considered that going back to a stock oil pump might solve, or at least significantly solve, the problem? i'm hearing nothing on this since the first post
Old Oct 10, 2006 | 02:28 PM
Kool88vette's Avatar
Kool88vette
WOW! I read that link and this thread. I'm new here and I always thought AFR was top shelf. I was thinking about buying their new Eliminators for my vette. Think I might port my L98 heads and add 1.6 RRs at the same time instead. Thank you all. You may have saved me some $ and a major headache.
Old Oct 10, 2006 | 02:54 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Originally Posted by jburnett
I don't have any on this computer and don't remember taking any pics but I do believe I have a set of AFR 190CNC LTx heads at my shop that we did this too.. If they are I'll take a pic and post them.
-Jeb
Cool,
Old Oct 10, 2006 | 03:01 PM
GeosFun's Avatar
GeosFun
The Eliminators are very new and have apparently addressed the oil problem. The oil issue discussed here relate to the vintage they are about to replace. If they live up to their billing, they are better heads than ported stockers by quite a wide margin.
Incidentally, I have the earlier version discussed here in AFR 195 Street heads, and have no problems, but I do not have a high revving engine either.
BTW TJ, the car is still running fine. Thank you so much for fixing it.
Geo
Old Oct 10, 2006 | 03:07 PM
rick lambert's Avatar
rick lambert
wasn't there a distinct problem with the AFR heads oil pooling or something of that nature? Last I ran a HV pump was in a built 327 and had no problems. There was a hugh post re; AFR heads not long ago..
Old Oct 10, 2006 | 04:16 PM
honda hunter's Avatar
honda hunter
I took them apart 3 times. replaced the seals. resealed the rocker studs. and pretty much gave up. debating on adding drain lines to the valve covers, or getting those cnc brodix heads heads.
Having the same problem with the same heads.
Old Oct 10, 2006 | 04:30 PM
DieL's Avatar
DieL
Tom. I have the EXACT SAMEproblem with My GM LT4 heads.
Here is what was happening. Under high rpm decceleration there would be smoke from the exhaust. AND just as your customer experienced My oil level would be 3-3.5 litres MISSING in just under 1 week.
My PCV tube was FULL of oil when i disconnected it. Under High rpm decceleration i can only assume the Canton pan which slows oil drainage to the pan with baffles causes the heads to have a higher level of oil. WHen the throttle blades are shut after a high rpm pull the Vaccum is incredibly high and is sucking the oil from the heads through the pcv.
Since a few days ago when I figured this out I plugged the throttle body and put a breather on the valve cover. A few days later My oil level is exactly as I left it. I'm going to put a breather on for a few weeks and re-check.
things to check..
Pull the intake duct and open the throttle blades. Check for oil all over the inside of the manifold. if there's oil in there than its not your rings, its the pcv sucking it in.
Good luck !
Old Oct 10, 2006 | 04:33 PM
DieL's Avatar
DieL
I also think this has a lot to do with the high volume pump. Thats where all the oil starving horror stories come from. The high volume pump is probably filling up the valve covers and perhaps even forcing oil to go into the pcv.
When I drop my pan again I may switch back to a stock volume pump.
Wish I could have respnded to this sooner but I just got married and its been a hectic week. Hope you all check your intake and pcv. Im betting its your problem.
Old Oct 10, 2006 | 04:43 PM
jburnett's Avatar
jburnett
On the contrary, man, they are EXCELLENT heads. This is primarily a problem on the older castings. Their new castings (the Eliminators) have addressed this issue. Even if they hadn't I still have enough faith in the way they work to spend 20 minutes a head fixing the problem. The 113's (stock L98's) were decent heads 15 years ago but they're pretty ****-poor now and you'll have a lot more in making them marginal than you would in buying a set of good heads.
-Jeb
Old Oct 10, 2006 | 04:56 PM
aqualung's Avatar
aqualung
I also have this problem. My first setup was ported LT1 heads and cam on a stock shortblock, stock oil pump. I was filling up 2 litres of oil a week. My intake had a light coating of oil on the inside. My plugs were fine.
I assumed because my heads were milled my intake was not seated properly and it was sucking in oil. Before I could figure this out, I had magor engine failure (my POS Comp R lifters spun in their bore and took out my cam.)
I now have a forged 396 shortblock, with ported LT1 heads and a Meling HV 55 high volume pump. I just got it back together last week. I was very happy until the LOW OIL light cam on. I was down 2-3 litres in 1 week.
I am going to check my PCV when I get home tonight. I am determined to figure this out. Two different set ups...both consume oil.
Can someone tell me... is it necessary to mill your intake if your heads are milled?
Old Oct 10, 2006 | 07:16 PM
STL94LT1's Avatar
STL94LT1
That depends on how much the heads have been milled.
Old Oct 10, 2006 | 07:36 PM
ralph's Avatar
ralph
My 406 will also pass quite a bit of oil thru the PCV system. I have a 10% over volume pump. The valve covers are well baffled and i'm using Brodix heads. I had to put a separator (AKA a compressor filter...lol) in the PCV line to prevent oil from being sucked into the intake. I used to have to drain the separator every 500-750 miles and the engine used about 1 Qt over that period. The engine has since sealed itself a little better and it doesn't consume quite as much oil. It's easy to test......just eliminate the PCV and replace it with a breather. If the consumption stops........there's your problem.
Old Oct 10, 2006 | 10:35 PM
  #33
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Here's a few pics from a set of 190's I modified for drainback.
Old Oct 10, 2006 | 10:58 PM
  #34
85vet's Avatar
85vet
Cruise-In V Veteran
Thanks for the pics - I saved them for future reference.
Jim
Old Oct 11, 2006 | 10:53 AM
  #35
tjwong's Avatar
tjwong
Now I have another customer, same heads AFR 210s on top of a all forged 383 with flat tops, one of my custom grind cams, and a Melling 55HV. He is sucking oil on high RPM deccel as well. I have got to get to the bottom of this. I have a brand new set of AFR 210s sitting on the shelf for my new engine. Maybe Tony Mamo will swap my set for one of their new eliminator series heads
Old Oct 11, 2006 | 12:08 PM
  #36
Caboboy's Avatar
Caboboy
Drainback was an issue I was very aware of when I did my build 2 or 3 years ago (AFR 195s) as John mentioned in post 13. I was not aware of the ball milling technique at that time, nor did I think about it. I darn sure would've milled them if I had known though, as I wanted the best performing head I could get at that time and was willing to make whatever allowances were necessary.
I think I got lucky, as my motor doesn't use much oil at all; and all I did was put in some viton seals and use a standard volume oil pump. My car only spins 5200 tops though so I'm sure that helps a bunch too. I bet a std volume pump and good seals would really help this problem a lot Tom.
Old Oct 11, 2006 | 01:35 PM
  #37
DieL's Avatar
DieL
I still think it's pcv
To AFR Heads again!
Old Oct 11, 2006 | 02:24 PM
  #38
aqualung's Avatar
aqualung
That is the million dollar question. My TEA receipt says they were milled .010. I don't think that alone would cause as much oil loss as I was having with my first build.
On my second build, my block was zero decked and my heads were reworked and improved by Meaux Racing Heads who said he only "kissed" the surfaced. The intake bolts were slightly off but we were able to get it down good and tight amd properly tourqed with RTV where needed.
I am going to try eliminating the PCV and see what happens.
Old Oct 11, 2006 | 03:02 PM
  #39
jburnett's Avatar
jburnett
.010" and you don't need to cut the manifold... After that you generally do.
-Jeb
Old Oct 11, 2006 | 03:11 PM
  #40
neat's Avatar
neat
I didn't read the whole thread, but here's an experience I had:
Same issues, lots of oil consumption, plugs looked OK, no oil out the back.
It turned out one of the wrist pins had walked out of the piston and gouged the cylinder wall. How the plug on that cylinder looked OK, I'll never know, but it did. Before it was torn down, it was going through a quart every 400 miles or so. No smoke, and it made 475 RWHP the same day it was torn apart. Ran smooth as could be.
One of the weirdest things I've ever seen.
