GM Performance rotors
Old Sep 16, 2001 | 02:35 PM
BrightAquaLT1's Avatar
BrightAquaLT1
Default GM Performance rotors
I remember that I´ve recently read that GM now produces performance rotors. Does anybody know how these differ from stock rotors and maybe the part numbers?
Old Sep 17, 2001 | 04:46 AM
vettewally's Avatar
vettewally
Default Re: GM Performance rotors (BrightAquaLT1)
I saw these at Carlisle, check with your dealer. Don't know about performance
[Modified by vettewally, 2:47 AM 9/17/2001]
Old Sep 17, 2001 | 11:06 AM
1991Z07's Avatar
1991Z07
They are DuraStop "Performance" Rotors. Your Chevy store needs to have the "Performance" catalog to find the numbers since it isn't in the normal GM Durastop book.
The numbers on them are that they are 30,000 PSI tensile strength castings, and are drilled & slotted. All of them are directionally vained to pump air through the rotor. I don't remember which ones go where, just that the 9646 & 7 are the fronts.
Part #'s are:
18039646
18039647
18039636
18039637
I've had 1 crack under hard track usage, but on close inspection there was a casting void that got by the QA inspector. GM replaced both fronts under warranty, even though only one was cracked.
If you have some good brake cooling ducts, they should hold up just fine under track conditions. I didn't have mine installed when I ran into that particular problem. GM was really interested in getting the broken one back to find out what went wrong.
Old Sep 17, 2001 | 11:25 PM
tommelton's Avatar
tommelton
Default Re: GM Performance rotors (Joe90)
Joe90,
Are these for the 12" brake rotors or 13" brake rotors (front of course)?
Thanks..
Tom Melton
82 CE
86 Z51 Coupe with 13" J55s
Old Sep 17, 2001 | 11:55 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: GM Performance rotors (tommelton)
Interested in these..thanks for the part #'s....how much will they set me back??
NIce Ride! :cool:
Old Sep 18, 2001 | 01:27 AM
jay17's Avatar
jay17
Have any pics?
Old Sep 18, 2001 | 10:36 AM
1991Z07's Avatar
1991Z07
They are the J55 front rotors = 13"
I don't have a picture of them on the car, but I scanned the one out of the GM Performance Parts Catalog. http://www.corvetteforum.net/c4/joe90/1991Z07/rotor.jpg
To GM Performance rotors
