383 stroker injector help
Old Oct 11, 2006 | 08:23 AM
BOWLING GREEN's Avatar
BOWLING GREEN
Default 383 stroker injector help
What is a good # injector for a 383 stroker with 53 mm throttle body and mild cam ,9.75 to 1 comp.about. Thanks.
Old Oct 11, 2006 | 09:21 AM
85vet's Avatar
85vet
Cruise-In V Veteran
What year? What will you be using the car for?
Autocross or road racing - go with higher # injector.
But for general use I use the following:
### Listen to your tuner first there may be a preference #####
If MAF - 24# Ford racing injectors w/ Holley adjustable fuel pressure regulator.
If Speed density - 24# may not be enough.
Injector use is a two edge sword - some say that my engine 383 cannot run good on 24# Ford injectors. But how many 383's that you know of can run on the street and run 10's at the strip and I am using the 85 original ecm and until we have cold great weather I am running slightly rich.
PS - don't be supprised if this thread gets spirited w/ opinions -
Old Oct 12, 2006 | 12:10 AM
goldeneye_vet's Avatar
goldeneye_vet
As stated above 24# FMS injectors with the Holley AFPR.
Old Oct 12, 2006 | 12:37 AM
sami85L98's Avatar
sami85L98
#24 fms.
Old Oct 12, 2006 | 12:40 AM
DieL's Avatar
DieL
NA 388 LT4 and am running Siemens #60 lb injectors. I've learned its not what # they are.. its the fine print and specs that determine how good the injector is and how well it can control.
Old Oct 12, 2006 | 05:29 AM
93 ragtop's Avatar
93 ragtop
First and foremost, use what your tuner suggest.
That aside there was a letter written in corvette fever, this month about injector sizing. Basically the answer was, its not really engine size etc. that dictates injector size. Its your horsepower output.
For what its worth, I am running stock injectors, but according to Alvin, I am starting to go lean on top end. He suggested I go with the ford 30lb injectors and that would give me some growing room as well.
Edit to add this link for you to look at. http://forums.corvetteforum.com/show...=injector+size Read the last post on it for a better understanding on injector sizing.
Old Oct 12, 2006 | 07:52 AM
Jimmy69's Avatar
Jimmy69
No guess work required, just some Math:
http://www.rceng.com/technical.htm#WORKSHEET
Plug in your numbers, and the recommended injector size is calculated for you. FYI, I run 30lb SVO injectors and they are at 80% DC at 6200 RPM where my peak HP occurs.
Jimmy
Old Oct 12, 2006 | 08:14 AM
Topload's Avatar
Topload
Ford 30# SVO's here.........
Old Oct 12, 2006 | 08:28 AM
FastVette94's Avatar
FastVette94
I'm running a self built 383 LT1.
30 lb/hr injectors here. With the 24lb injectors the Duty Cycle was maxing out above 85% (which is wide open from an injectors standpoint).
With the 30's im in the 70s DC under WOT. 30# for the win!
i run 11.9s at 117mph and it is an every day driver.
If you're a TPI car then you might be able to use the 24#s since they are restricted on air/horsepower. I'm buzzing my motor to 6500RPM.
Old Oct 12, 2006 | 11:06 AM
djxib's Avatar
djxib
I am just about to go with a matched set of the #60 Siemens - I have a supercharged 383 LT1. Has your experience been a good one?
Old Nov 22, 2006 | 01:18 AM
dads01dream's Avatar
dads01dream
Seems for most blower cars, the worksheet keeps coming up with 50+lb. injectors.... Guess it'll be time to step up to 60's with my new combination.
To 383 stroker injector help
