Which head porter
Old Oct 11, 2006 | 10:35 AM
jodyeastman's Avatar
jodyeastman
Default Which head porter
Hey guys. I am still undecided in which heads to go with. I plan on doing a 383 (not quite a daily driver but want to remain drivable) and am wondering with a decent budget which direction would you guys go? Here are some options I am looking at.
Old Oct 11, 2006 | 10:53 AM
STL94LT1's Avatar
STL94LT1
I used CNC Cylinder Heads, and I'm very happy with their performance.
Old Oct 11, 2006 | 01:58 PM
95PoloVert's Avatar
95PoloVert
Active Streak: 90 Days
You'd have to define "decent budget" and tell us what your ultimate goals are for the car...but I can tell you that Lloyd is consistently turning out great results on stock LT1 castings at a great price.
For another few hundred bucks, Bret Bauer will custom-grind a cam tailored to make the most of Lloyd's work. Tough to compete with for under $2K, IMO.
-Scott
Old Oct 11, 2006 | 02:30 PM
aqualung's Avatar
aqualung
Lloyd Elliot has a lot of happy z28 customers and he uses Bret Bauer cam for proven packages and good prices.
Advanced Induction also has a great reputation but a little more pricey.
If you can wait a long time, Meaux Racing Heads also does awesome work. As well as Port Pros.
Speaking of waiting...if you haven't bought your castings yet, wait to see what these guys can do with the new AFR eliminator heads. I can hardly wait to see flow numbers off those. Unless of course AFR is full of crap about the potential.
Old Oct 11, 2006 | 02:43 PM
jodyeastman
Sorry on the budget question. I am lookong for a decent 500HP (I will be making a 383 with these heads). As For cost, from what I am seeing, for under 2500 you could buy heads from any of these listed.
Old Oct 11, 2006 | 02:45 PM
jodyeastman
Yeah, I was reading that thread. I would like to do this in the comming winter.
Old Oct 11, 2006 | 08:04 PM
Curveit's Avatar
Curveit
My $.02 worth... AFR Eliminator heads @ $1400, then sell your stockers for $$$ and recoup some of your money. Probably cheaper than reconditioning, and porting yours. Most likely flow a whole lot better too.
Old Oct 11, 2006 | 08:32 PM
LD85's Avatar
LD85
www.cfmperformance.com
Old Oct 11, 2006 | 08:48 PM
95wht6spd's Avatar
95wht6spd
I have Lloyd's heads/intake and a Bauer cam. I don't think you can beat the HP for the $.
Old Oct 11, 2006 | 10:54 PM
Red Tornado's Avatar
Red Tornado
this is a solid alternative
Old Oct 12, 2006 | 01:22 PM
aqualung's Avatar
aqualung
I see you live in Victoria, BC. I am not sure if you have emissions testing there or not, but if you do, you are going to be hard pressed to get 500 hp and still pass emissions.
It is my understanding that a 383 with ported LT1 heads will make between 420 and 440 RWHP. This is with a large, but streetable, cam that WILL NOT pass emissions.
I just built a 396 with excellent flowing LT1 heads and a Bret Bauer emissions cam. I have not put it on the dyno yet but I am guessing it will be anywhere between 380 and 400 RWHP. Passing emissions is my biggest obstacle to making more power.
If you waited this long, I urge you to wait a little longer and get the Eliminator heads ported by Advanced Induction.
BTW my name is Jody too.
Old Oct 12, 2006 | 02:08 PM
1991Z07's Avatar
1991Z07
Can't say anything bad about their work or performance...http://www.cncheads.com/corporate/corporate5.htm
Old Oct 13, 2006 | 12:14 AM
farscape1a's Avatar
farscape1a
i currently have a whole top end setup from advanced induction (heads, ported intake manifold, cam) and i have to say that i'm thoroughly impressed of the quality of work and the customer service. i've been in close contact with Ron and he is truly a wonderful guy. he will take the time and ask you as many questions needed to find out what kind of setup you are looking for. i live in NY, but i have people to pass my car. so i can run whatever i wanted to. if you're looking for around 500hp at the crank, look into the 190cc CNC ported heads from AI with the ported intake and matched cam. if you need an emissions cam, that's easy for them also. i'm posting pictures soon of the 383 i'm building. so, stay tuned for that. good luck with your project.
Old Oct 13, 2006 | 12:26 AM
STL94LT1's Avatar
STL94LT1
I'm also running one of Pete's custom grind camshafts.
Old Oct 13, 2006 | 09:57 AM
BlackC6LS3's Avatar
BlackC6LS3
Precision Porting made it happen for me. I only went with their stage two heads, and with a hot cam kit and tune, I went for 14.00 @ 99 to 12.79 @ 111. Bang for the buck, I doubt these guys can be beat.
To Which head porter
