rear bumper removal
Old Oct 13, 2006 | 07:07 AM
nightsor's Avatar
nightsor
Default rear bumper removal
could somebody explain or steer me in the right direction on how to remove the rear bumper on my 90 vette so i can have it repainted
nightsor@hotmail.com thank you
Old Oct 13, 2006 | 08:28 AM
KeyWestJack's Avatar
KeyWestJack
Try this, its pretty inexpensive and filled with good stuff.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Old Oct 13, 2006 | 09:57 AM
mikey whipreck's Avatar
mikey whipreck
-Remove the rear wheel wells and license plate.
-Remove teh 4 10MM nuts between the quarter panel and bumper on each side, accessible after the wheel wells are removed.
-Remove the rear tail lights by reaching through the license plate light hole.
-Remove 4 10MM nuts on each side of the bumper between the quarterpanel and bumper (at the uppermost left and right curves) accessable through the lense openings.
-Remove the single nute & bolt behind the license plate, and 2 larger bolts above each tailpipe extension.
It should slide off.
EDIT:::
Old Oct 13, 2006 | 10:01 AM
nightsor's Avatar
nightsor
thank you for all the help i appreciate it nightsor
To rear bumper removal
