Eliminate optispark.
Old Oct 12, 2006 | 09:23 AM
americanlt1's Avatar
americanlt1
Navigator
Default Eliminate optispark.
Just wanted advice from lt1 guys that have done away with thier optispark. I have a f.a.s.t. b2b that is not installed yet and I know I'll have to mount some sort of crank trigger but, what else will I need and what are my options? Also, if I use ls1 coils can they be mounted under the motor? I don't like the look of the coils on top of the motor. My turbos are mounted high so I may have the room under the motor for the coils. Thanks, any help is appreciated.
Old Oct 12, 2006 | 09:52 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
With the LTCC conversion I used, I still use the opti. I never investigated further what other options there were.
The coils can be mounted anywhere you want, depends on how long you want those plug wires to be. I don't know about heat issues though.
I don't know how the Delteq setup works, but supposedly it's a little simpler.
