Injectors
Old Oct 14, 2006 | 09:33 AM
peggysspace@yahoo.co's Avatar
Default Injectors
My injectors are leaking, pretty good. Is this a job for a pro? Or can I be guided through it? Thanks for the help
Old Oct 14, 2006 | 09:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Very doable by the average DIY'er
Do a search and you will find many a write up on this subject.
Old Oct 14, 2006 | 09:40 AM
Sam Lam's Avatar
Sam Lam
Peggy: It is realatively simple....assuming you have tools and some mechanical skills. I have a Word doc write up on how to change them out. Send me your email and I will shoot it to you. Read the info and then you can decide if you want to give it a shot.
Old Oct 14, 2006 | 09:43 AM
AGENT 86's Avatar
AGENT 86
http://forums.corvetteforum.com/sear...archid=3333108
Old Oct 14, 2006 | 09:45 AM
peggysspace@yahoo.com. I am can do some mechanical. I like to learn. Thanks for the help. Peggy
Old Oct 14, 2006 | 09:51 AM
RRT vette's Avatar
RRT vette
It's not too bad if your just replacing the injectors. The TB can stay bolted to the plenum, remove all the hoses and cables. Remove the plenum and not the runners. Unbolt the fuel line bolts and the fuel rail. Just the hight points. Sam Lam can send you a better description.
To Injectors
