Throttle Body Reconditioning?
Old Oct 14, 2006 | 05:47 PM
anthony605's Avatar
anthony605
Default Throttle Body Reconditioning?
Does anyone know of a business that reconditions TPI Throttle Bodies? Of if there is any way to do it yourself? THe shaft on mine seems to have alot of play in it. THanks
Old Oct 14, 2006 | 07:10 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
David Koldos mailto: dkoldos@ameritech.net
Old Oct 15, 2006 | 02:08 AM
Dan Parker '96's Avatar
Dan Parker '96
Excellent product.
Old Oct 15, 2006 | 08:31 AM
anthony605's Avatar
anthony605
Thanks for the quick posts! Does he have a web site? Thanks!
Old Oct 15, 2006 | 09:39 AM
KENS80V's Avatar
KENS80V
No web site...but he has done two for me...great workmanship. He was away from doing them last year due to personal problems but he is back at it again.
Ken
Old Oct 15, 2006 | 11:32 AM
anthony605's Avatar
anthony605
Thanks again! What does he charge and what exactly is done to the TB? THanks
Old Oct 15, 2006 | 12:27 PM
Wheelman's Avatar
Wheelman
Old Oct 15, 2006 | 05:33 PM
KENS80V's Avatar
KENS80V
He drills out the bores to 52mm and installs needle roller bearings for the throttle shaft. New larger throttle shaft blades are then installed. A minor modification is then performed to the egr passage to make it perform correctly with the larger bores. Price is just over the $200 mark.
Old Oct 28, 2006 | 11:10 AM
Red Tornado's Avatar
Red Tornado
Arizona Speed & Marine (AS&M) is another source that can be tried. They will bore out your stock 48mm to 52mm and recondition as well http://www.azspeed-marine.com/
That being said, the Dave Koldos route is probably your best bet.
To Throttle Body Reconditioning?
