LOWERING QUESTION
Old Sep 17, 2001 | 07:11 PM
black bart's Avatar
black bart
Default LOWERING QUESTION
I would like to lower the back of my C-4 but all lowering kits that i see just have longer bolts this will allow the car to ride on the sway bars instead of the springs. I don't want to make it ride like a truck just to lower it. Has anyone modified the linkage on the sway bars to compensate for the lowering.
Old Sep 17, 2001 | 07:25 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: LOWERING QUESTION (black bart)
No, I just installed the two bolts and dropped it 1 1/4"; rides fine and handles better than before.
Old Sep 17, 2001 | 08:43 PM
jimbjr's Avatar
jimbjr
Default Re: LOWERING QUESTION (65Z01)
Had the rear lowered with the bolts, rides fine.
Old Sep 17, 2001 | 09:16 PM
BobMachus's Avatar
BobMachus
Lowering both sides simutaneously shouldn't really affect way bar action, since it pivots in the frame bushings.
Bob
Old Sep 17, 2001 | 10:29 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
hello black bart hey my e mail is jparr@hotmail.com jay
Old Sep 18, 2001 | 10:30 AM
Aggravated4life's Avatar
Aggravated4life
Default Re: LOWERING QUESTION (jparr)
Ive lowered the rear as well a little bit...the longer bolts set the spring height on where the car sits and wont affect the sway bar.
However, I went back to an almost stock ride height..everytime there was a dip in the road, the car would bottom out hard and bust my lower back on the ride...it wasnt very comfortable.
I decided to raise the car back near stock height but till a little lower then stock and found a good compromise.
If you have alot of bad roads or so-so roads and drive the car everyday, you may not like it lowered, but whoah will she feel like she handles even more.
Old Sep 18, 2001 | 11:10 AM
black bart's Avatar
black bart
Default Re: LOWERING QUESTION (Bill's86Coupe)
Thanks for the info guy's Bill sounds like you were running out of shock travel that is another problem that could arise from lowering. I would like to have the back a little lower but i think i drive too fast for it to be practical. i have went over hills and had the exhaust hit the ground but i will admit that i got a good bit of hang time on that one. :D
To LOWERING QUESTION
