Brake job
For a 1996 coupe vette
It would be a good idea to get a little help from someone who knows what they are doing
Maybe even someone from the forum who is near you
At least get a service manual
A small mistake on the brakes can have serious consequences
If doing both:
Front caliper mount bracket: 21mm
Rear caliper mount bracket: 18mm
Rear caliper bolts: 15mm on top and an internal hex on the bottom (I forget that size), both backed up by a 17mm wrench on the guide pins.
Bleeder screws: 10mm
Blue lock-tite unless you're using new bolts from the dealer (as recommended in the service manual).
Torque wrench, although mine is unwieldy in the rear wheel wells, and I go by feel.
It's nice to have sockets and wrenches.
And yes, get the service manual. I had never done brakes of any sort before and found myself double- and triple-checking everything. Twice. Not that it's difficult, I just wanted to make sure.
An inspection mirror was a big help in making sure the e-clip was securely installed on the front caliper pin. It's hard to get on there, and hard to see.
If doing both:
aluminum housing, steel piston.
if you get the rebuild kits from Mid America, they come with new bolts too.
to push out the piston, use a bike pump that will go to like 75 psi, and be careful where you put your fingers. WHAM!
For the calipers & brake lines:
Sockets/box/open-end wrenches: 10,13,14,15,16,17,18mm
Flare/line wrench: 12mm
Slip joint pliers
Screwdrivers
Wire brush/ wire wheel
For replacing the master cylinder proportioning spring:
socket/box wrench 13mm
Flare/line wrench 12, 14mm
Socket for end plug 15/16 inch
Snap-ring pliers
They also give a parts list (pn's are for Mid America Motors)
Caliper paint kit: 106-121 (red)
Front Brake pads, OE style: 611-088
Rear brske pads, OE style: 611-090
Power Slot front rotors (pair): 611-600
Power Slot rear rotors (pair): 611-603
Caliper hardware kit (four kits req'd): 611-045
Master cylinder proportioning spring: 603-179
Braided steel brake lines (set of 4): 603-455
Mityvac brake bleeder kit (plastic): 100-788 or (metal) 100-785
If you can get hold of the magazine (Aug. 2006) there are a lot of pictures which may help. If not let me know and I'll try to scan the article and email it to you.
Good luck
Good luck
true true... has anyone ever used pbblaster or something to spray on the backs to loosen anything up? Might be a good pre-step to do the night before attempting a rotor change in the future... just a thought?
the ones in my wife's altima I had to beat up pretty hard, the rotors were full of dents when i finally broke them free LOL
