MSD Optispark Timing Adjust
Old Oct 26, 2006 | 05:29 PM
Vette Threat's Avatar
Vette Threat
Default MSD Optispark Timing Adjust
I've tried a search but can't find it anywhere. If I tighten the timing screw, does that advance or retard timing?
Old Oct 26, 2006 | 06:16 PM
jonecap's Avatar
jonecap
I'd think tightening would advance the timing. You can tighten it and if the idle rpms increase, you've likely increased the timing. Or you could call MSD and ask.
Old Oct 26, 2006 | 08:27 PM
Desert1957's Avatar
Desert1957
Default MSD Distributor Info
See if this helps you out , took a while to upload , great pictures , good info..
http://www.msdignition.com/pdf/8381_frm27275.pdf
Desert
Old Oct 27, 2006 | 06:35 PM
RetroTA's Avatar
RetroTA
Default Msd
MSD says that 2.5 turns out is equivelent to factory opti, I read a post quite a while ago that said his would not run unless it was screwed in all the way. I just installed mine and started with it all the way in but the car surged at idle sometimes almost quiting. After messing with it and several trips up and down the road, I found it ran best with it turned two times out. I guess it depends on your cars set up or MSD has some quality control issues. Even the instructions dont specify. Good luck talking to MSD Tech. I had an unrelated question and I could have got a better response from my Dog!
Old Oct 27, 2006 | 10:27 PM
Lichen's Avatar
Lichen
I may be an idiot, but I didn't know that you could set the timing via the optispark.
Old Oct 27, 2006 | 10:46 PM
STL94LT1's Avatar
STL94LT1
Stock optispark, no. MSD unit, yes.
Old Oct 27, 2006 | 11:37 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
That's MSD's gimmick with their opti, adjustable timing.
Old Oct 28, 2006 | 12:33 AM
imaruby's Avatar
imaruby
When I called MSD it was two turns out for 0 advance.
Mine was 2 & 1/2 turns out when I got it.So I guess that anything between the two will work.The ECM will adjust it.
If anyone has better info let us know.
Keep waving,Ray
Old Oct 28, 2006 | 03:33 AM
RetroTA's Avatar
RetroTA
Thats Right! I believe MSD engineered that timing screw in there to cover they're butt. Because every application is different.
To MSD Optispark Timing Adjust
