1991 Interior Lights
Old Oct 26, 2006 | 06:50 PM
LS6 Motor's Avatar
LS6 Motor
Default 1991 Interior Lights
Hey guys, that I would post a quick question because I had to go to work, and didn't have time to go through my FSM yet.
I was replaced the weather-striping on my doors, and when I was replacing the door panel on the drivers side, I had a little issue. I didn't disconnecting the battery, because I had backed the car out of the garage, so everything was still live. At any rate, when replacing the light assembly that is above the door release, I had a fine blade screw driver, and touched the light terminals. I heard something pop, and now none of the rest of the interior lights that come on when you open the door, work.
Also, I notice the digital readout on the electronic HVAC control is blank. Is this a common fuse, I looked quickly at the fuse panel on the passenger side, but I was only looking at the abreviations.
Anyone experience this before, just thought I would ask before I start tearing into things? THANKS!!
Old Oct 26, 2006 | 07:26 PM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
I have a '91 also and it sounds from your explanation that it's fuse position 1 (top left side) of passenger side panel. It's a 15 amp fuse. If your glove box and map lights are also out it's the one.
Suggest if you are keeping the car get a service manual or at the very least an owner manual.
SAVE THE WAVE!
Old Oct 26, 2006 | 07:31 PM
Steel Blue 91's Avatar
Steel Blue 91
Start with the courtsey light fuse. Marked CSTY in the fuse panel.
Old Oct 26, 2006 | 08:12 PM
vetteman42's Avatar
vetteman42
Steel Blue 91 has confirmed the CTSY fuse is the position 1 top left side of paasenger panel.
Good Luck!
SAVE THE WAVE!
Old Oct 26, 2006 | 08:42 PM
LS6 Motor's Avatar
LS6 Motor
You guys are KING, thanks, I will get it in the morning, when I get out of work.
Oh yes, I do have all the manuals, both FSM, and owners, it's just I was running out the door for work, and didn't grab them, which is why I posted. I'm working 6 P.M.- 6:00 A.M.
Old Oct 27, 2006 | 04:27 PM
LS6 Motor's Avatar
LS6 Motor
Quick follow up, I replaced the fuse, and everything works fine. Also, the read out on the Electronic Air Conditioning is back, and looking at the electrical schematic in my FSM, I see that is tied to this also. Thanks again!!
Old Oct 27, 2006 | 07:29 PM
vetteman42's Avatar
vetteman42
Glad we were able to help.
Checked out your pictures and your ride is lookin' good!
I've got to get mine posted.
SAVE THE WAVE!
Old Oct 27, 2006 | 09:38 PM
LS6 Motor's Avatar
LS6 Motor
Thanks vetteman42!!! I just picked up my new evaporator, so on to the next project
To 1991 Interior Lights
