How to pull codes on a 96 using digital display?
Old Oct 26, 2006 | 08:26 PM
thriftyj's Avatar
thriftyj
4th Gear
Default How to pull codes on a 96 using digital display?
I want to buy a 96 but don't know how to pull the codes using the digital display before I buy it. How is it done? Also, is there a reference guide that explains the codes? Much thanks to anyone who can help.
Old Oct 26, 2006 | 08:45 PM
Louis Bartay's Avatar
Louis Bartay
Is there a Auto Zone Auto Supply where you live? If so they will scan for codes free. I will look in my two GM Shop Books. I am sure some of the other LT4 owners will post.
Old Oct 26, 2006 | 09:22 PM
thriftyj's Avatar
thriftyj
4th Gear
I don't own the car yet. I need to be able check out the car at the guy's house. Somebody told me you can access the codes through the digital display that's on the dashboard, by turning the key and pushing some buttons on the dash, Do you know how to do that?
Old Oct 26, 2006 | 09:33 PM
Steel Blue 91's Avatar
Steel Blue 91
Go here and read:
http://www.corvettephotographs.com/c4vettes/codes.htm
The codes are listed here:
http://www.corvetteactioncenter.com/....php?qstId=631
Last edited by Steel Blue 91; Oct 26, 2006 at 09:38 PM. Reason: Added link for codes
Old Oct 26, 2006 | 11:15 PM
RRT vette's Avatar
RRT vette
Originally Posted by Steel Blue 91
Old Oct 27, 2006 | 07:37 AM
runner140*'s Avatar
runner140*
For $15.95 on Ebay, you can purchase an OBD11 code reader. Might be worth it to you IMHO.
Old Oct 27, 2006 | 12:35 PM
bogus's Avatar
bogus
From what Gordon Killebrew told us, the OBDII codes are too long to fit on the speedo... is that right???
Old Oct 27, 2006 | 12:58 PM
gdaddee's Avatar
gdaddee
A 1996 and later are OBDII compliant. You have to have a code reader that plugs under the dash.
Old Oct 27, 2006 | 08:14 PM
thriftyj's Avatar
thriftyj
4th Gear
What about codes for the The Anti-Lock Brake System (ABS) , Automatic Slip Regulation (ASR), Selective Ride System (SRS) as well as the Air Conditioner Controller, the Air Bag's computer system (called the DERM module) plus the Central Control Module (CCM). Can you tell me how to find these codes?
Thanks for the help. I'll buy the engine code reader and be able check it out on my Venture Van and Impala as well.
Have you heard of anyone checking codes on a car before they buy it?
Old Oct 27, 2006 | 08:15 PM
bogus's Avatar
bogus
I do it all the time. If you don't check codes, you deserve what you get.
Old Oct 27, 2006 | 08:36 PM
tonymax2's Avatar
tonymax2
By all means, yes.
Old Oct 27, 2006 | 08:38 PM
thriftyj's Avatar
thriftyj
4th Gear
Can you provide any insight into reading codes from the other systems?
ABS, ARS, CCM etc?
Old Oct 27, 2006 | 09:07 PM
Bob CTS's Avatar
Bob CTS
I might be crazy, but most over the counter readers are only going to read the Engine codes and not the ABS or Body control codes, to get all these your looking at a Tech or Genisys scanner which is big bucks. Just my thoughts
To How to pull codes on a 96 using digital display?
