Holly Stealth Buildup
The box you have is the same one I'm running. Mine is black powder coated though. Where did you get it from? I didn't think there were any left out there.
John
Purchased it from Dennyz51 here on the forum, waiting to receive it... Would really be interested in ALL thats required with this conversion setup... it would definately save me a bunch of time and energy...
1. Small base distributor with external coil(camaro, firebird or GM truck).
2. Re do fuel lines.
3. Re do both pcv lines.
4. New thermostat housing with different angle.
5. New upper radiator hose.
6. Cut off coolant line on bottom of throttle body (it will hit thermostat housing if you don't).
7. Cut off the bottom of the throttle body linkage or it will rub on the fuel line when going to wide open throttle (dont go crazy with this).
8. Foam stick tape to stick on bottom side of hood. Throttle body and corner of new plenum will rub against the hood on hard acceleration.
9. Match up plenum opening with throttle body openings. Do this before final install.
10. Use rtv sealant on the 4 bolts that hold the plenum to the base to prevent vacuum leaks. Also between the plenum and the base around the 4 openings. Gaskets supplied are very thin.
I am very happy with the manifold and plenum set up.
Feel free to email me with questions throughout the process if you like.
Good luck,
John
jdwyer01@tampabay.rr.com
Am I out in left field hear?
sorry, missed the intent of your post...
Did Dennyz51 make it?
I am interested in finding something like that...
http://www.fuelinjectorclinic.com/index2.htm
