Holly Stealth Buildup
Old Oct 28, 2006 | 12:57 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Holly Stealth Buildup
Well, i did it, i'm in the process of purchasing this Holly Stealth setup from Dennyz51: so... I have the following (1) 48mm TB, (2) set of stock injector cleaned and flow, (3) new gasket set, (4) 1.6 SA RR's, (5) new edelbrock elite valve covers & feltpro gasket set, but the main part is the Stealth setup.
Will the TB and Injectors be a good start?
side note: the Stealth will go out to get chromed and new SS hardware along with AN fittings.
Any and all design and comments will be greatly appreciated.
thanks guys
vinnies87
Old Oct 28, 2006 | 01:48 PM
LD85's Avatar
LD85
If your engine is stock, you "may" need to go to a 52MM, TB, you will need a AFPR for sure to boost the fuel.
Do you have a small distributor?
Old Oct 28, 2006 | 02:10 PM
hippy's Avatar
hippy
How much power do you think the igloo will make with the stealth ram?
A 350 doesn't need a 52 TB unless you feel the need to blow $300. Stock injectors should be good to 350 rwhp, at least mine are.
Old Oct 28, 2006 | 04:13 PM
LD85's Avatar
LD85
I am not familiar with this custom plenum, it may not need a small cap distributor.
My HSR does need the small cap, regardles, I think you will like the HSR on your L98,
Old Oct 28, 2006 | 04:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you going to have to modify the hood ??
Old Oct 28, 2006 | 04:29 PM
AGENT 86's Avatar
AGENT 86
Checked out the 4 sale section and see the setup will fit under the hood. Your motor will be unbearable to look at on a sunny day.
I see more trophies coming your way.
Old Oct 28, 2006 | 07:08 PM
vinnies87's Avatar
vinnies87
I was hoping the igloo would add at least 20hp to the overall, but a 12pack will do..
Old Oct 28, 2006 | 07:09 PM
vinnies87's Avatar
vinnies87
Thanks bud,,, looking forward to ANOTHER mod or mods... thanks
Old Oct 29, 2006 | 02:08 AM
vinnies87's Avatar
vinnies87
TB should be fine @ 48mm, stock i think is 42mm, so should not be an issue there.
good question: i have the stock distributor now, so i'm checking into this part... have time while i put the whole thing together...
And yes, already have the AFPR, did that change with my new injectors.
thanks
vinnies87
Old Oct 29, 2006 | 02:10 AM
vinnies87's Avatar
vinnies87
Which one did you get, while we're on the subject of Dist caps...?
vinnies87
Old Oct 29, 2006 | 05:01 AM
USAsOnlyWay's Avatar
USAsOnlyWay
MSD 8366, he showed me how to mount my 6AL and helped me out in finding the right wiring pigtails for the samll cap 8366 swap. Thanks again Larry!
Old Oct 29, 2006 | 06:54 AM
LD85's Avatar
LD85
I did not realize the stock TB was 42MM
Here is some interesting reading for an HSR
http://www.gmhightechperformance.com...hird_gen_iroc/
Old Oct 29, 2006 | 06:57 AM
LD85's Avatar
LD85
Here is a pic of my distribtutor clearance, its tight.
Old Oct 29, 2006 | 06:58 AM
LD85's Avatar
LD85
Old Oct 29, 2006 | 07:02 AM
LD85's Avatar
LD85
No problem Chris ,
I would get a stocker from the Junk Yard for less than $225 I paid,
here is the info for the Distributor I bought, plus you need a remote mount coil with two wires to go to the distributor, dont be discouraged, its not a big deal at all
http://www.msdignition.com/dist_2.htm
Old Oct 29, 2006 | 07:41 AM
bjankuski's Avatar
bjankuski
The stock throttle body is 48mm, and that should be fine on a near stock engine.
Old Oct 29, 2006 | 02:18 PM
vinnies87's Avatar
vinnies87
Thanks guys, great info... I'll be working on getting everything together... hope you don't mind me pm you guys since you've already done most of the prim work... thanks again
vinnie
To Holly Stealth Buildup
Old Oct 29, 2006 | 04:21 PM
USAsOnlyWay
Well the last time you asked for help it looked like I responded...
http://forums.corvetteforum.com/show....php?t=1466361
Truth be told, I didn't know you were in that thread, I just remember posting up the stuff. Funny though.
Old Oct 29, 2006 | 05:50 PM
JOHN89's Avatar
JOHN89
Larry,
Your set up looks beautiful! I notice only three bolts on the throttle body. How's that working out? No leaks? Do you have any 1/4 mile times yet? I'm still tuning but I'm gearing up for a visit to the track. I just installed a 58mm thottle body so I have to make some changes again.
As mentioned above the stock t.b. is 48 mm not 42.
Anyway glad to see another Vette with a Stealth Ram!
John
Old Oct 29, 2006 | 09:18 PM
LD85's Avatar
LD85
Originally Posted by JOHN89
Larry,
Your set up looks beautiful! I notice only three bolts on the throttle body. How's that working out? No leaks? Do you have any 1/4 mile times yet? I'm still tuning but I'm gearing up for a visit to the track. I just installed a 58mm throttle body so I have to make some changes again.
John
Thank you very much,,,,JOHN89,,,,,there are indeed 4 bolts in the TB,
I did go to the track but my new clutch slips as bad as the one before. I may try to dyno the car, I don't know if the slippage would mess up the results or not. I will install a street twin or a RAM push type conversion by Spring, for sure
