Rockers?
Old Nov 2, 2006 | 06:32 PM
fc_soldier's Avatar
fc_soldier
lol
Old Nov 2, 2006 | 10:15 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Oh yeah, I would also update the studs to 7/16".
Old Nov 3, 2006 | 07:05 AM
87vette's Avatar
87vette
Is this a good mod to do on a high mileage engine that hasn't been rebuilt? Will this cause complications down the road? The reason I ask is because I have 111,000 miles on my vert.
Old Nov 3, 2006 | 08:40 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Originally Posted by Hot Rod 90
Led Zeppelin would by my choice, for real rockers and real power
As long as you change the valve springs at the same time youll be fine.
Old Nov 3, 2006 | 08:50 AM
Pete K's Avatar
Pete K
With the exception of cost, I do not think there are any disadvantages to running roller rockers.
Old Nov 3, 2006 | 10:10 AM
87vette's Avatar
87vette
How difficult is it to do this? I have never done it before but have accomplished alot of projects I took on with my vert.
Old Nov 3, 2006 | 10:25 AM
Pete K's Avatar
Pete K
5 hr job. I remove all of the spark plugs to close the valves, then use the rope trick.
Old Nov 3, 2006 | 10:53 AM
STL94LT1's Avatar
STL94LT1
It's not that difficult, but a little time consuming.
Old Nov 4, 2006 | 01:55 PM
fc_soldier's Avatar
fc_soldier
Should I change my springs on my low mileage car too?
Old Nov 4, 2006 | 02:02 PM
STL94LT1's Avatar
STL94LT1
I would. With stock LT1 springs and 1.6 rockers, you'll be very close to coil bind. At the very least I would install the LT4 springs.
Old Nov 4, 2006 | 02:19 PM
AKS Racing's Avatar
AKS Racing
Do the '96 LT1 require self aligning rocker arms? Do they have guide plates (or cast in pushrod guides) installed from the factory?
Reason is, I have a set of NSA rockers that I am looking to install on a 96 LT1.
Thanks in advance,
Aaron
Old Nov 4, 2006 | 02:53 PM
STL94LT1's Avatar
STL94LT1
The 96 LT1's came with self-aligning rockers, no guide plates.
Old Nov 4, 2006 | 08:03 PM
  #33
pipe's Avatar
pipe
So if i'm going to a 1.6 roller rocker on my L98 I should also change my valve springs? If I don't will it weaken the springs down the road? What springs should I use for the swap from stock rockers to the 1.6 rr's Pipe
Old Nov 5, 2006 | 02:14 AM
  #34
Casethecorvetteman
Yes you should change your valve springs
(no one seems to have noticed that has been said allready!!)
The stock springs are about all that is stopping you from revving past 5,850 rpm. Change the springs and youre good for 1.6:1 RRs and also more revs. You can reuse the stock springs if ya like, after all, you own the car.
Old Nov 5, 2006 | 02:28 AM
  #35
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
So are you saying that he should change his valve springs?
Old Nov 5, 2006 | 07:42 AM
  #36
Casethecorvetteman
HAHAHA!!! Mate i dont know whether to laugh or cry!!!
Old Nov 5, 2006 | 09:04 AM
  #37
fc_soldier's Avatar
fc_soldier
So what your tring to say is? LoL
To Rockers?
Old Nov 5, 2006 | 09:57 AM
  #38
Casethecorvetteman
Yeah mate, go with some really good springs and you can then rev higher
Old Jan 13, 2007 | 05:42 PM
  #39
89er's Avatar
89er
Default Different problem but same topic
I am putting '85 heads with '85 intake, etc. on a '90 block to put in an '85 coupe. Do I use self aligning rockers or not? On vendor sites they say '86 small block and up to use self aligning types but I don't know if that applies with '85 heads.
Old Jan 15, 2007 | 06:34 AM
  #40
Desert1957's Avatar
Desert1957
Hey,
Does anyone know the aftermarket valave spring part number (Crane , Comp Cams , etc) for a 1992 LT1 ? That's if I do not want to use the LT4 springs with my Roller Rocker upgrade.
