Lightest Weight Alternator
Old Oct 29, 2006 | 10:13 PM
NitrousSam's Avatar
NitrousSam
Default Lightest Weight Alternator
Anyone got any recommendations for a lightest weight street duty alternator? I do need something that will put out at least stock amperage because I am running an aftermarket ignition, two fuel pumps, an electric water pump, electric fan and a 4 solenoid nitrous system. Any recommendations would be appreciated.
NitrousSam
Old Oct 29, 2006 | 10:26 PM
cv67's Avatar
cv67
St. Jude Donor '05
Powermaster makes one I believe, check Jegs or Summit
Im also looking for a mini alt with a 1 wire hookup for the 67 so it can be mounted down low and close to the W/P.
Old Oct 29, 2006 | 10:43 PM
red L98's Avatar
red L98
i think MSD has light/small alternator
Old Oct 29, 2006 | 10:53 PM
Pete K's Avatar
Pete K
East Coast Auto Electric is another quality company.
Old Oct 29, 2006 | 11:00 PM
redrose's Avatar
redrose
cs-110 from a 91 chev cavalier 4-banger is 11 lb, tiny, has 3 mounting lugs (pick any two)...its rated for 80 amp service...vette alt wiring will plug in....GM sells a higher output ''race'' version that is popular with nastycar racers....some of the rice burners have smaller ones
Old Oct 30, 2006 | 11:49 AM
Wildcat1's Avatar
Wildcat1
I was in the market til I found that the pieces I was researching weren't light enough to warrant the swap. I believe stock is somewhere between 10-15 lbs from what I found.
Here's one site: http://go.mrgasket.com/pdf/alter_starters.pdf
Another: http://www.cantonracingproducts.com/...ternators.html
I got a bigger weight loss going to a lighter battery and didn't lose anything in the process. Now if my alternator ever dies, I may try one of these.
To Lightest Weight Alternator
