LT1 Block
Old Nov 4, 2006 | 06:39 PM
CorvAdel's Avatar
CorvAdel
Originally Posted by lefoy84
The blocks all have the same casting numbers. The only way to tell if it's 2 bolt or 4 bolt is to look. The 2 bolt is still good for 400 HP plus.
I was under the impression that the last three letters of the eng. no. pre-fix tells what type of vehicle the block was going in to. E.g. Corvette LT1's used ZAC, indicating 300hp, auto trans. motor, and ZUB 300hp manuals, in 1992.
I found this out after buying an LT1 thinking it was a vette engine, only to find out that it was for a Camaro, by virtue of its pre-fix ending in WTA.....
I was told that this meant that I had a two bolt main block.
If this info is wrong, I'd appreciate being corrected..
Old Nov 4, 2006 | 06:46 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm not aware of what you are speaking of but it could well be indicative of something. But what lefoy was talking about is the casting number of which the last three numbers are displayed prominently on the side of all LT1/4 blocks. Those last three digits are 327. I've had more than one person in my garage when I had one on the stand who asked me if I was building a 327 to put in my Vette!
Old Nov 4, 2006 | 07:00 PM
lefoy84's Avatar
lefoy84
http://www.chevy-camaro.com/chevy-ca...es.asp?group=6
http://www.chevy-camaro.com/chevy-ca...?group=6BLOCKS
350 - There are two blocks, one with two-bolt mains and one with four-bolt mains. They both have the same 10125327 casting number, so there’s no sure way to know which one you have until you get the pan off. However, if it came out of a Corvette, it should be a four-bolt block, and if it came out of anything else, it was supposed to be a two-bolt. GM used the two-bolt block for everything but the Corvette because it had plenty of strength and it weighed a little bit less.
Old Nov 5, 2006 | 09:34 AM
aboatguy's Avatar
aboatguy
Originally Posted by BrianCunningham
are they BIG BORE by any chance? I'd put myself down for one, even in cast iron. a 427+LTX would rock!
Old Nov 5, 2006 | 10:00 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
From my sources, the LT1 suffixes are as follows:
1992=ZUB for manual trans
1992=ZAC for automatics
1993=ZVB for manual
1993=ZVA for automatic
1994=ZWB for manual
1994=ZWA for automatic
1995=ZUF for manual
1995=ZUC for automatic
1996=ZXD for manual(LT4)
1996=ZXA for automatic
all blocks were 10125327
Old Nov 5, 2006 | 10:19 AM
Corvette Kid
Originally Posted by DieL
I've been speaking to a manufacturer to produce an aluminum LTx block for some time now. We're working out details on a prototype block that I may have by the end of the year .. and its aluminum
Dammit, now I've got to start planning another build!
1993=ZVB for manual
1994=ZWB for manual
1995=ZUF for manual
So CorvAdel was indeed onto it. Interesting, I can't believe I've never seen that info on here before. So if 4 bolt block hunting, one could simply look for the suffixes. If it doesn't have one of these then there's no need to pull the pan to look further.
Old Nov 5, 2006 | 02:19 PM
tjwong's Avatar
tjwong
Ed, what are you looking to build? I have a seasoned LT1 F body short block in the shop that I can build a good foundation with. A two bolt block when you stud the main line caps are good for 500hp. Unless you plan on hitting it with NOS or supercharging it, there is no need to go with installing a set of splayed billet caps which will easily drive the cost of machine work and parts up another $1000. If that is what you want I would highly recommend Pro-Gram Engineering's billet main caps, these are of the highest quality and fit like a glove, plus they don't a problem with dip sticks fitting right.
