LT1 Block
Old Nov 2, 2006 | 06:30 PM
fc_soldier's Avatar
fc_soldier
Default LT1 Block
Are all LT1 small blocks the same?I have a 96 LT1. Cause I want to get a block to build up and I want to know if I have a bigger market.
Old Nov 2, 2006 | 06:32 PM
VenkmanP's Avatar
VenkmanP
Two blocks, 4 bolt and 2 bolt.
Old Nov 2, 2006 | 07:08 PM
DieL's Avatar
DieL
Basically your answer is yes. Corvette LT1 blocks are 4 bolt mains and Camaro were 2 bolt.
I've been speaking to a manufacturer to produce an aluminum LTx block for some time now. We're working out details on a prototype block that I may have by the end of the year .. and its aluminum
Old Nov 2, 2006 | 07:13 PM
rklessdriver's Avatar
rklessdriver
Actually there are 3 different Gen II blocks. But only 2 of them are useable for performance build ups.
1)5.7L 4bolt caps (Corvette only) Alum Heads (LT1 300hp, LT4 330hp)
2)5.7L 2bolt caps (F & B bodies) There are 2 different versions of this engine F bodies have Alum heads and big cam(LT1 275hp). The B bodies have cast iron heads and smaller cam(LPO9 260hp).
3)4.3L 2bolt caps (B body)You don't want one of these under any circumstances they are useless.
Will
Old Nov 2, 2006 | 07:15 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've got a nice Vette LTx bare block for sale but it'd be around $150 to ship it to you.
Old Nov 2, 2006 | 07:21 PM
fc_soldier's Avatar
fc_soldier
Thanks for the info
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
are they BIG BORE by any chance? I'd put myself down for one, even in cast iron. a 427+LTX would rock!
fc_soldier's Avatar
fc_soldier
How much you want for it? How much does it weigh?
Old Nov 2, 2006 | 07:23 PM
STL94LT1's Avatar
STL94LT1
Old Nov 2, 2006 | 07:26 PM
lefoy84's Avatar
lefoy84
The blocks all have the same casting numbers. The only way to tell if it's 2 bolt or 4 bolt is to look. The 2 bolt is still good for 400 HP plus.
Old Nov 2, 2006 | 10:16 PM
93-383's Avatar
93-383
the 2 bolt block has one advantage . It can be drilled for a splayed 4 bolt main cap like the ones from Moroso whare as those of us with corvette blocks have to settle for the parallel 4 bolt. Although I doubt that the splayed design has much advanage for a street car
Old Nov 2, 2006 | 11:57 PM
Corvette Kid
I think they're about 175 lbs. if I remember right. Anyhow, it has to be shipped freight. I know about what it costs because I had one shipped to me from out your way. We used Forward Air, they're very reasonable. The block is out of a 34K mile car and has never been bored or otherwise modified. The price is $400 plus shipping. These Vette blocks can sometimes be difficult to run across. It took me a while to find one. Like you, I wanted to do my build ahead of time to minimize downtime.
Old Nov 3, 2006 | 12:14 AM
VenkmanP's Avatar
VenkmanP
Some cars other than Y-bodies came with 4 bolts. LT4s for starters. People have also reported LT1 F-bodies with 4-bolts from the factory.
He asked about LT1 blocks. That is not an LT1 block.
Old Nov 3, 2006 | 07:57 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
http://www.automotiverebuilder.com/ar/ar99928.htm
Old Nov 3, 2006 | 10:04 AM
FD2BLK's Avatar
FD2BLK
From Mojo's link
"There was only one block used for the 265 cid version of the LT1. It’s a 10168588"
Old Nov 3, 2006 | 10:57 AM
STL94LT1's Avatar
STL94LT1
Originally Posted by FD2BLK
From Mojo's link
Say it aint so, our expert stat's guy is wrong?
Old Nov 3, 2006 | 11:56 AM
LT4POWR's Avatar
LT4POWR
O'Rily I'd love to see (and get) an aluminum LTx block w/ a bigger bore option...I'd assume they'd sell well, if priced similar to the LSx motors...keep us posted
To LT1 Block
Old Nov 3, 2006 | 12:29 PM
VenkmanP's Avatar
VenkmanP
From Mojo's link
As powerful as he is, even Mojo can't turn an L99 into an LT1 by simply renaming it.
Old Nov 3, 2006 | 08:04 PM
Mr Mojo's Avatar
Mr Mojo
Hey I just posted the link, I didn't write the page.
Old Nov 4, 2006 | 01:50 PM
fc_soldier's Avatar
fc_soldier
