PCM connector pin removal tool??
Old Nov 6, 2006 | 05:58 PM
leadfoot2's Avatar
leadfoot2
Default PCM connector pin removal tool??
Anyone know where I can get a pin removal tool for the connectors on the PCM in my '94?
Old Nov 6, 2006 | 06:19 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
A tool truck or a real parts store such as NAPA.
Old Nov 6, 2006 | 11:32 PM
VenkmanP's Avatar
VenkmanP
Anyplace that carries the packard connectors should also carry the tools.
Old Nov 7, 2006 | 02:56 AM
ben73's Avatar
ben73
I use these:
Just remove the soft tip off one end and they will push the terminals right out once you get the hang of it...
Old Nov 7, 2006 | 09:34 AM
Muffin's Avatar
Muffin
Originally Posted by ben73
I use these:
Why didn't I think of that? I ground a very small screwdriver into a blade. Worked very well.
Old Nov 7, 2006 | 10:13 AM
tjwong's Avatar
tjwong
You should not need any tools to remove the pins. Just remove the colored outer shell of the connector, and open the grey shell, then with a pick you need to push in the white retainer tabs. Once the colored shell is removed and the retainer is removed the pins will just pop out.
Old Nov 7, 2006 | 11:39 AM
leadfoot2's Avatar
leadfoot2
tjwong:
Thanks for the tip. I didn't know the connectors could be disassembled. I know the removal tool for the Packard weather pack connectors doesn't work - they have larger pins and are released from the front.
To PCM connector pin removal tool??
