I need some information reguarding the powerdoor locks on a C-4, 1993.
The power lock lever on the door will not lock or unlock the doors. This
is a recent development. The Pass Key will unlock but not lock the doors. I checked the fuse and it appeared fine. Thanks
The power door locks on my 1990 coupe are slow. The key no longer unlocks the driver's door. Fortunately, the passenger door lock still works with the key.
Eckler's sells a kit to replace the worn parts. That kit would probably solve your problem. I need to order that kit.
