Shocks
Old Nov 10, 2006 | 03:57 PM
fjm59vette's Avatar
fjm59vette
Default Shocks
94 6Spd coupe. I know I need my fronts cause I bottom real easy on speed bumps. But Rears seem ok and I really dont want to replace them if they dont need em.
So my question is - Is it best to replace all 4 now or can I do only my fronts.
Call me lazy but dont want to spend the money or time on rears that may, probrably dont need to be replaced.
Advice welcomed !!
Old Nov 10, 2006 | 05:01 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Yes, it is best to replace all four shocks...and yes, you can replace just the fronts.
How many miles are on the rears??
Originally Posted by fjm59vette
Call me lazy
Okay, you're lazy (or cheap, or both).
Now...the decision is yours.
Larry
code5coupe
Old Nov 10, 2006 | 05:29 PM
Aardwolf's Avatar
Aardwolf
Old back shocks on mine made the car harsh over bumps. If you are not bothered by this, just replace the fronts.
Old Nov 10, 2006 | 07:13 PM
LS6 Motor's Avatar
LS6 Motor
Just my .02$ worth, but I would do all four. Usually you can get a deal on four from places like Ecklers or Mid-America.
Now if your paying for someone to install them, I understand the reluctence, as everything is double if it is a Vette..............
Old Nov 10, 2006 | 07:48 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It's fine to do fronts now and rears later. Just be sure to match them up. It is somewhat normal for the fronts to wear out quicker than the rear.
Old Nov 10, 2006 | 08:08 PM
aminnich's Avatar
aminnich
Larry
code5coupe
Lazy? Cheap? Both? Heck if you really are all of those just replace the left front, after all that is the only side of the car you sit in.
Old Nov 10, 2006 | 08:24 PM
creoleman's Avatar
creoleman
Old Nov 11, 2006 | 03:46 AM
Gar's Avatar
Gar
I recently replaced JUST THE FRONTS! on my 95 A4 w/FE1. These cars are way to soft in front IMHO. I installed a set of Z51 bilsteins. YES I am very happy with the way it rides now. Hope this helps. AS soon as wally wallet allows I'm putin' a set on da back.
Old Nov 11, 2006 | 02:13 PM
fjm59vette's Avatar
fjm59vette
Not really worried about the money.... But since Im gonna attempt to do the job myself - I think Im gonna just do the fronts. Since thats where all the action (and weight) is. I really dont feel the rears need replacement.
Just wanted some constructive opinions - I guess you'll always get both !!!
Old Nov 12, 2006 | 12:53 AM
rocco16's Avatar
rocco16
dont want to spend the money...
Well, which is it?
Larry
code5coupe
Old Nov 13, 2006 | 10:45 AM
fjm59vette's Avatar
fjm59vette
Well, which is it?
Larry
code5coupe
Sorry if I confused you Larry. Dont want to spend the time or money doing rears if they dont need it. That was my point from the start.
Old Nov 13, 2006 | 10:53 AM
BADDUCK's Avatar
BADDUCK
He's easily confused!
Old Nov 13, 2006 | 11:34 AM
pcolt94's Avatar
pcolt94
Just did all 4 on my 94 with HD Bilsteins. The rear has much more contact with the ground and does not come around when I hit a bump in a turn. The entire ride is much better and pleasurable to drive. Don’t have to avoid all the manholes and such I used to drive around.
I’m sure the fronts added to the better ride where now I’m not knocked around like I was before. Even the wife likes it better.
Old Nov 13, 2006 | 11:38 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Since thats where all the action (and weight) is. !!!
The weight distribution of a C4 is about 50/50
Do all 4
Old Nov 13, 2006 | 04:46 PM
rocco16's Avatar
rocco16
I understand.
Now, keep this in mind: if the fronts are worn out, why wouldn't the rears be worn out as well? Haven't they traveled just as many miles as the front shocks....?
I'd replace them all, if it were my Corvette. ....ESPECIALLY if money was not an issue.
Larry
code5coupe
Old Nov 13, 2006 | 09:03 PM
black88z51's Avatar
black88z51
what if you leave the old rears and the new fronts raise the front of the car . just replace all 4 the same time it's only $150 more if your doing it yourself.
Old Nov 13, 2006 | 09:45 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
This is one of the funn-er threads I've read in awhile. I like it.
To Shocks
