a few minor problems, help please.
Old Nov 15, 2006 | 02:51 PM
deadite84's Avatar
deadite84
Default a few minor problems, help please.
I will be brief so as not to waste time,
1. Under accelerationn there is a "hollow?" sound to the engine or exhaust, but you canrt hear it in neutral, only when it is actually moving can you hear it. I know it is not a knock, i know what that sounds like. i feal no power loss, but it doesnt sound right.
2. I hear a rattle/ knocking sound coming from the rear of my car, like around the rear tire. Maybe a bad bearing?
Thats it for know any help would be great.
Old Nov 18, 2006 | 02:55 AM
deadite84's Avatar
deadite84
anybody?
Old Nov 18, 2006 | 12:32 PM
RRT vette's Avatar
RRT vette
It's difficult to diagnose sounds from the forum. Here is a bump anyhow.
1. not sure
2. could be a bad U joint.
Old Nov 18, 2006 | 01:50 PM
85RIT's Avatar
85RIT
Does the sound under acceleration almost sound like someone is beating on a empty tin can? Mine does that too a bit, when I really get on it, it almost sounds like a shields is vibrating.
I can't find anything wrong. It won't do it in neutral, that is correct.
Is this the sound your hearing?
Old Nov 19, 2006 | 03:22 AM
deadite84's Avatar
deadite84
No, it sounds almoust like an exhaust leak, but i cant find one anywhere? I had a similiar sound coming from my suzuki GSX-R1000 (motorcycle) and it was a fouled out sparkplug, causing cylinder to fire weakly. I pulled a spark plug yesterday, and it was pretty nasty, so i am assuming that may be the problem. I will have the plugs replaced, i took one look at the other seven i didnt pull and decided i didnt want to do it, and see if that stops the sound.
To a few minor problems, help please.
